    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    Shave the block overdrive crank pulley install? Goin dual pulley need insight
    So I'm trying to research to this using higher than a 180mm overdrive pulley for dual pulley setup.i want to run a 189 or 183mm at least but from what I've been told you have to shave the block to clear the 7 rib OEM style belt if over 180mm. Is there any specifications or specs it needs to be shaved to to clear or maybe a write up on this can't find any info on it
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    It's in the long beyond stage 2 thread, here is one post but you may want to read more.
    http://www.audizine.com/forum/showth...1#post11722544
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Apr 05 2016
    Portland, OR
    You can just file it away like Swank did see post 1 in that thread for details: http://www.audizine.com/forum/showth...lopment-thread
    It is a very minor modification and not required if you run a 6-ribbed belt.
    Geoff
    Jul 01 2012
    Quote Originally Posted by whiped View Post
    Whipped any clue on what size belt or brand is preferred was looking into 6 rib but couldn't find any options
    Apr 05 2016
    Portland, OR
    Contact Fluidampr or S4matty depending what direction you are going. (Fluidampr or KA)
    They will take care of you and provide everything you need. Just let them know you want to run a 6-ribbed belt.
    Geoff
