Results 1 to 3 of 3
    Senior Member Three Rings jonnybravo's Avatar
    Nov 23 2009
    San Jose
    Help! P0480 4527 Fan fault
    My A4's fans keeps running after the car is turned off and its killing my battery. This is the fault it shows even though it doesnt throw a code on the dash. Both fans run when the car is off so it seem like they both function fine. Is it the fan control module? How hard is it to fix/replace?
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    I had this same issue after doing some carbon cleaning. Behind the I take manifold, there are a bunch of electrical harnesses. One of them wasn't seated properly. You can start there
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    if you end up needing a fan control module I have a low mileage one for sale
