Results 1 to 4 of 4
    Veteran Member Three Rings HIS4's Avatar
    Aug 15 2004
    Mililani, HI
    Clicking sound under engine cover when engine turned off and spinning down
    I have this strange clicking sounds that seems like its coming from just under the front drivers side portion of the engine cover. I don't hear anything when the car is running but when i turn off the engine and everything spins down there is a clicking sound as everything comes to a stop. I don't see any belts or pulleys spinning at the time and it almost sounds like electrical relays clicking but it sounds like the frequency slows as everything comes to a stop. Then one last click as everything shuts down that sounds like it come from somewhere near the back of the alternator. Anybody have a clue what this could be?
    2011 Meteor Gray A4 Avant - Premium, AMI (retrofit), Bi-xenon (retrofit), Bluetooth, Homelink, VAG mods, TunerDomes.com LEDs, Revo Stage I
    2016 Sapphire Blue Porsche Cayman GTS - Still thinking about mods but not much needed...
    Jun 13 2016
    New York
    I have the same sound and it look to me that when you turn off the car the ac start droping a little bit of water and it touch the break or something hot and i make that sound... it could be wrong
    Sent from my SM-G930T using Tapatalk
    Aug 15 2004
    Mililani, HI
    It sounds like this is definitely something related to A/C. I tried turning off the A/C well before I turned the car off and when the car is turned off there is no noise.
    Junior Member Two Rings
    Mar 25 2009
    Grapevine, TX
    Quote Originally Posted by HIS4 View Post
    I just had the a similar sound that was A/C related, the radiator cooling fan on the drivers side was loose on the electric motor shaft, the blades were clicking on the radiator fins. Of course I found it after it had rubbed a hole in the radiator. I ended up replacing the fan and the radiator.
