Results 1 to 11 of 11
    Account Terminated Four Rings
    Mar 22 2016
    73 Jimmy 496 BBC
    Longer wheel lugs with stock wheels
    Maybe Jason from ecs can comment on this. If I take off my flush kit will the longer wheel lugs work without the spacers on stock peelers? I've tried everything under the sun to not have vibrations and I still get it. And I threw away my stock lugs. Thanks.
    Apr 11 2012
    have you tried 10mm up front instead of 8mm? The 10's have much more of a lip. I'll never go less than 10mm for spacers again. I remember reading somewhere if the bolts don't hit anything behind the hub, you should be good.
    Mar 22 2016
    73 Jimmy 496 BBC
    I haven't tried 10s just the 8s. The only time I get vibration is if I'm over 60mph and I mash the throttle it vibrates. If I'm just cruising at 80 or any Mph there hardly anything. I don't know if I want to waste the monly just to have it vibrate still. I was even thinking about taking the fronts off and leaving the rears to see if it was just the fronts.
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by evil35r View Post
    Don't do it. My brother did this accidently and the lugs basically machined away at the wheel bearing causing it to fail. His situation was slightly different in that he used the wrong seat bolts for the wheels which caused them to install deeper than expected.
    Sent from my SM-G930W8 using Tapatalk
    Mar 22 2016
    73 Jimmy 496 BBC
    The fronts that come with the flush kit are 35mm what are the stock length? It should be fine since they all are ball seat
    Jan 09 2008
    Winnipeg
    I would be doing some measurements first and a test fit. You need to figure out how far the bolts go into the hub and how much, if any, pokes through the back of the hub with the spacers installed. Then see if you have the additional clearance for them to turn in that much further.
    Mar 22 2016
    73 Jimmy 496 BBC
    Yea I was gonna run one in prior to doing it without the wheel or spacer on to see how far it'll go in. If all goes well I'll probably leave the rears spaced and the fronts stock it'll look super staggered but it may look good. If not I'll just take the rears off and sell the kit.
    Jun 29 2015
    Sorry but if it primarily only vibrates when you mash it then it sounds more like a bad engine mount then spacers.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Stock are 27mm.
    As others have said, you'd want to check for clearance at the hub. They can poke through, and cause damage.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Mar 22 2016
    73 Jimmy 496 BBC
    It only vibrates though when at higher speeds. If I mash it around 20 or from a dig its fine until I reach 80 or so and starts to vibrate
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Just go with the 10mm. Call ECS and tell them you're getting vibrations and they should send you the 10MM.
    Euro Tails Crew
