I have a 2005.5 S4 with about 105k miles on it. I usually drive it pretty tame and am pretty easy on it. I have noticed though if I put in sport mode and really lay into it the check engine light comes on (flashing). Of course when that happens I lay off of it and just when I am about to pull over the light will go away (after about 5-10 seconds). The light stays off from that point on. Here is a copy of the one scan I did after this happened last time. Has anyone else ever had this happen or have any idea what would be causing this problem? I have never had it happen when I am not in sport mode. I'm researched the codes and am seeing that fuel injectors seems to be a similar theme among them. Looking in my Bentley manual I see that testing the fuel injection system and actually getting to the injectors themselves seems like quite the job and the testing requires special tooling.
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - MIL ON
17537 - Fuel Trim; Bank 2 (Mult)
P1129 - 002 - System too Rich - Intermittent
16559 - Fuel Trim; Bank 2
P0175 - 002 - System Too Rich - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
16689 - Cylinder 5
P0305 - 001 - Misfire Detected - Intermittent
16692 - Cylinder 8
P0308 - 001 - Misfire Detected - Intermittent
16691 - Cylinder 7
P0307 - 008 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
