Some info Eventuri just pushed over
Power gains: 22hp 34ft-lb Mid-range and 17hp Peak RPM : Power was measured back to back with the stock airbox on a car with stage 3 map and pulley upgrade. To be clear, the car had the map and pulley for both the stock airbox and the Eventuri:
Component photos:
This is a fully sealed intake system which has a dual cold air inlet so solves 2 issues - de-restricted airlfow and low IATs.
An integral part of the design is the carbon duct which seals the filter to the cold air feed:
With the additional carbon scoop at the front, this channels cold air into the filter for IAT values to rival the stock system. With the Patent Pending Venturi Housing, the airlfow remains laminar and able to move as it would in an open system so you get the best of both Worlds.
Here is a short video of how it looks and sounds:
All the carbon components are made from high quality Prepreg carbon fibre.
