Results 1 to 3 of 3
    Veteran Member Four Rings BirdmanQ5's Avatar
    May 31 2012
    2017 Audi S3
    Toronto, ON
    Question Amber reflector delete + VCDS
    Now that I've got your attention, can anyone help me figure out how to turn these stupid ambers off? I've searched forums, found vagcom codes, but nothing seems to work. The coding I used is as follows, but the lights are still active:
    Disable orange side markers in head lights
    09 - Central Electronics
    Adaptation - 10
    (6) Leuchte8FL LB39-Dimmwert AB 8 -> 0 (left headlight)
    (6) Leuchte9FL RB2-Dimmwert AB 9 -> 0 (right headlight)
    Defaults are 127
    In addition, I've tried to disable the winking lights using the following coding instructions, however I keep encountering an error that says "out of range" when I try to switch the parameters to non-active:
    DRLs stay on with turn signal
    Adaptation - 10
    (8)-Leuchte2SL VLB10-Lichtfunktion C 2 -> "not active" (default "Blinken links aktiv (beide Phasen)")
    (8)-Leuchte4TFL LB4-Lichtfunktion C 4 -> "not active" (default "Blinken links aktiv (beide Phasen)")
    (8)-Leuchte3SL VRB21-Lichtfunktion C 3 -> "not active" (default "Blinken rechts aktiv (beide Phasen)")
    (8)-Leuchte5 TFL RB32-Lichtfunktion C 5 -> "not active" (default "Blinken rechts aktiv (beide Phasen)")
    Any insight that can be provided would be greatly appreciated. Sorry if there is an obvious location for the solution, but I've searched a bunch of different forums and can't seem to get a solid answer. Fairly new to the platform, had the car a month and it's all very different from my B8.5.
    Thanks,
    Alex
    2017 AUDI S3 | TECHNIK | DAYTONA GREY | BLACK OPTICS | SUPER SPORT SEATS | ADVANCED HANDLING | TECHNOLOGY PACKAGE | AWE SWITCHPATH 102MM | ED SPOILER | 034 SPRINGS + REAR SWAY | VORSTEINER VFF102 20x9 ET35 CARBON GRAPHITE | THINKWARE F770
    2016 AUDI S3, 2013 AUDI S4, 2011 AUDI Q5, 2010 AUDI A4, 2006 AUDI A4
    @IALEXSERBERT | @AUDI_TN | @SIXAUTO
    AUDITRUENORTH//
    WWW.SIXAUTOCONCIERGE.COM
    Sep 14 2006
    You can't turn them off :(
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Active Member One Ring juice2boost's Avatar
    Aug 09 2016
    Long Island, NY
    only way to get ambers off is to unplug them or get ecodes. and throwing this out there, the LED lights dont wink and there is not way to change the signals. (if you have LED package)
