Results 1 to 20 of 20
    Oct 06 2016
    Mississauga, Ontario, Canada
    VCDS Log Interpretation/Transmission Reset
    Hi,
    I have a few questions. I have a 2009 A4 B8 3.2L v6 with 2g MMI and Nav.
    I got kinda screwed when I purchased the vehicle and I just had to do a carbon cleaning which cost me quite a bit. It's actually in the shop right now. I scanned my car before using VCDS and these are the faults I found. Im hoping someone could shed some light.
    5 Faults Found:
    7119 - Cylinder 4
    P0304 00 [236] - Misfire Detected
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 23
    Mileage: 122477 km
    Date: 2016.07.08
    Time: 18:03:42
    Engine speed: 799.00 /min
    Normed load value: 17.6 %
    Vehicle speed: 0 km/h
    Coolant temperature: 57 °C
    Intake air temperature: 54 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.577 V
    Unlearning counter according OBD: 40
    Engine speed: actual: 800 /min
    MAF_ENVD: 98.04706 mg/stroke
    Coolant temperature (unfiltered): 69.0 °C
    Engine: operating status: IS
    T_AST_ENVD: 0.00 s
    Vehicle speed: actual: 0 km/h
    7117 - Cylinder 3
    P0303 00 [236] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 27
    Mileage: 122477 km
    Date: 2016.07.08
    Time: 18:03:42
    T_AST_ENVD: 0.00 s
    7115 - Cylinder 2
    P0302 00 [096] - Misfire Detected
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 125067 km
    Date: 2016.09.07
    Time: 15:11:50
    Engine speed: 851.00 /min
    Normed load value: 16.9 %
    Coolant temperature: 51 °C
    Intake air temperature: 51 °C
    Voltage terminal 30: 11.882 V
    Unlearning counter according OBD: 36
    Engine speed: actual: 832 /min
    MAF_ENVD: 92.60000 mg/stroke
    Coolant temperature (unfiltered): 51.8 °C
    T_AST_ENVD: 0.00 s
    6371 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [236] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 27
    Mileage: 122477 km
    Date: 2016.07.08
    Time: 18:04:51
    Engine speed: 733.00 /min
    Normed load value: 30.2 %
    Vehicle speed: 5 km/h
    Coolant temperature: 60 °C
    Intake air temperature: 46 °C
    Voltage terminal 30: 13.913 V
    Engine speed: actual: 1440 /min
    MAF_ENVD: 136.17647 mg/stroke
    Coolant temperature (unfiltered): 71.3 °C
    Engine: operating status: PL
    T_AST_ENVD: 77.10 s
    Vehicle speed: actual: 11 km/h
    6128 - Fuel Injector #4 (N33)
    P0272 00 [096] - Contribution/Balance Fault
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 125154 km
    Date: 2016.09.08
    Time: 11:37:36
    Engine speed: 1632.00 /min
    Normed load value: 58.4 %
    Vehicle speed: 17 km/h
    Coolant temperature: 90 °C
    Intake air temperature: 44 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 13.507 V
    Unlearning counter according OBD: 25
    Engine speed: actual: 1632 /min
    MAF_ENVD: 256.01176 mg/stroke
    Coolant temperature (unfiltered): 90.8 °C
    Engine load: 58.203125 %
    Vehicle speed: actual: 17 km/h
    ^^ I suspect the above is due to carbon deposits
    Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
    Part No SW: 8T0 035 729 M HW: 4E0 035 729 A
    Component: Interfacebox H43 4610
    Revision: 00000000 Serial number: 340JZ087513985
    Coding: 0000003
    Shop #: WSC 02135 785 00200
    VCID: 4385256A0254F25AFD-8016
    Subsystem 1 - Part No: 8T0 919 609 D
    Component: E0380 BedienteilH08 0100
    Subsystem 2 - Serial number: 00000000170481
    Subsystem 3 - Serial number: 0111.10.080000000100010336ÿ
    Subsystem 4 - Serial number: 010336ÿ
    1 Fault Found:
    02244 - Button in Control Head is Stuck
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 126791 km
    Time Indication: 0
    Date: 2016.09.30
    Time: 12:43:24
    Freeze Frame:
    Bin. Bits: 00000000
    Bin. Bits: 0000000
    Bin. Bits: 001
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0094
    Revision: 4FB50047 Serial number: 4700F08923800F
    Coding: 000303
    Shop #: WSC 02391 823 56573
    VCID: 4A9B084EE57E23123E-801E
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H04 0150
    Serial number: 180496FA200908
    2 Faults Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 4
    Reset counter: 34
    Mileage: 126790 km
    Time Indication: 0
    Date: 2016.09.30
    Time: 03:06:00
    03041 - Energy Management Active
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 34
    Mileage: 126790 km
    Time Indication: 0
    Date: 2016.09.30
    Time: 06:06:00
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Part No SW: 8K0 959 760 HW: 8K0 959 760
    Component: MEM-FS H05 0043
    Revision: AA000000 Serial number: 00001001167575
    Coding: 00581B00000000000000
    VCID: 77FD81BAC60C6EFA91-8022
    1 Fault Found:
    02095 - Component Protection Active
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 126403 km
    Time Indication: 0
    Date: 2016.09.28
    Time: 09:47:35
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
    Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
    Component: DSP Prem H14 0400
    Revision: 00H14003 Serial number: 34814003335901
    Coding: 030101
    Shop #: WSC 12336 024 394758
    VCID: 3F8D299AAEBC96BA99-806A
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 27
    Mileage: 125431 km
    Time Indication: 0
    Date: 2016.09.11
    Time: 13:55:12
    Freeze Frame:
    Voltage: 11.90 V
    Temperature: 45.0°C
    Temperature: 48.0°C
    Bin. Bits: 00000100
    ^^ I tried to do some research on this but came up empty handed. What exactly is component protection? I know it can only be removed at a dealer since they need to be connected to some network but do I need to fix this? Does it affect my sound?
    Now onto the transmission issue. I've noticed that sometimes ( a decent amount of times) it jerks in 1st, 2nd, and 3rd gear. Higher gears are fine. Usually happens when coming to a stop, or accelerating. I did some research and found this link
    http://www.audizine.com/forum/showth...h-occasionally
    I also found this TSB on another page (which I can't locate anymore...) but it references this. Not sure exactly what a TSB is. TSB# is 2021193/1
    It is supposed to reset the transmission. Is this doable with vagcom using the instructions in the link just above?
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Regarding scan, delete your old errors and make a fresh scan, many old errors which probably have no impact anymore!
    Component protection, visit dealer, may affect sound and other functions(probably some modules are replaced, but without dealer visit, some functions are disabled or restricted, depending which modules are changed out).
    TSB, visit dealer if this service action is for you, its free of charge, you cant do this with vcds(you can do basic ops with vcds as discraibed on this thread, but always good to use tsb, if its related to your car, as the tsb you reffered has probably sw upgrade also)!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Oct 06 2016
    Quote Originally Posted by Gunnark100 View Post
    Thanks! I'll clear the faults and scan again when I get the car back.
    The vehicle had an accident on it in 2013 on the rear left, which is where the amp is. I wonder if that has anything to do with it.
    Could you elaborate more on TSB? Is the service free even if I'm outside warranty? Is it just a software update?
    Oct 21 2012
    Earth...
    Quote Originally Posted by sriyegna View Post
    Yes it must be free as its so to say factory approved action, when something is faulty from factory and discovered later, nothing do to with warranty. I had one tsb done year ago, long time after warranty, it was free. I asked will this tsb action like expiry with time - they said no.
    By this thread, looks like its just sw update for trans ecu, so you cant do this with vcds.
    http://www.audiworld.com/forums/a4-b...iness-2764796/
    Oct 06 2016
    Thank you for your help!
    Oct 21 2012
    Earth...
    You welcome, if your rear was damaged and amp was replaced, then yes, you may have cp active because of that- but its not a 100% fact and you see your driver seat memory cp was activated like 2 weeks after , so clear your faults, drive a bit and make fresh scan, if cp still active(should be) visit dealer!
    Oct 06 2016
    So I just called my local Audi in Oakville, Ontario, Canada and they said that this tsb isn't covered for free by my VIN :s. They said that it would need to be diagnosed before we do the tsb and there is the standard cost of $149/hr for that. If an issue is found, then they would do the TSB which would be factored into the $149/hr diagnostic cost.
    Are they ripping me off or is this right?
    Oct 21 2012
    Earth...
    I cant comment this(local guys should know better), but your car is 2009 and this tsb was for 2009 tiptronic gearbox, so if this have not been done before you, it must be free, how they diagnose you have faulty software or not, testdrive and checking sw number on your scan for 149 lol. Sry i dont have this tsb or software description data.
    Have you any records of gearbox oilchange?
    Oct 21 2012
    Earth...
    Post your autotrans module scan!
    Oct 06 2016
    I checked Canadian and us recalls for 09 a4s online and I couldn't find that TSB anywhere.
    I bought the car at 118k km and its now 127k km. I dont have any records of gearbox oil change. Is this the same as transmission fluid? Which also may be unchanged
    Oct 21 2012
    Earth...
    Yes gearbox oil is transmission fluid as audi stated lifetime liquid lol.
    I cant comment why there is below mark "warranty", but on top you see related "all vin range", so if you have sw number not as listed on table 021, update should be in my logic free of charge, nothing to diagnose if you dont have updated sw already!
    http://workshop-manuals.com/audi/a4_...012/page_4981/
    Hope it helps!
    Oct 06 2016
    Hope it helps!
    Cheers! I'll show them this page when I head over. The main category of the tsb is 2.0L and not the 3.2 but the charts clearly indicate an update on the 3.2
    Oct 21 2012
    Earth...
    Compare with your scan, to be ahead of them:)
    Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
    Part No SW: 8K0 927 158 D HW: 0B6 927 156
    Component: 0B6 32 FSIUSA H04 0020
    Revision: --H04---
    Coding: 001002
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_TCMAL651 A01004
    ROD: EV_TCMAL651.rod
    VCID: B73E7C5F0E3B528600-80E2
    Oct 06 2016
    Revision: --H04---
    Coding: 001002
    Revision: --H04---
    Coding: 001002
    Shop #: WSC 02145 785 00200
    VCID: 377D41BA8E8CAEFA51-8062
    No fault code found.
    ^^is from my scan. What does the scan you provided indicate? I noticed we have the same part and component.
    Oct 21 2012
    Earth...
    Revision: --H04---
    Coding: 001002
    Its not my scan, as you see you have old sw - Component: 0B6 32 FSIUSA H04 0020 , so this tsb is for you, just lie about all other symptoms also and they must update this for free:), nothing to diagnose there!
    Oct 06 2016
    Thanks again. I went to two local Audi dealers. Mississauga and Oakville. Even though I showed them my scan, and the current version, they said that tsb are just bulletins and not covered if the car is out of warranty.
    They're saying they would still need to diagnose it at $149/hr and check for transmission faults... Which I know there are none.
    I'm going to try and reset my transmission learning through vcds. If that doesn't work, I'm not sure if I want to go to a dealer and do this.
    Oct 21 2012
    Earth...
    Yep, my fault also, mixed tsb with recall etc...
    http://repairpal.com/blog/recalls-ts...ou-have-to-pay.
    There should be somewhere instruction how to make proper adaption yourself for tiptronic and oilchange will not harm also, plenty treads you find here as well. I have done twice sw upgrade to gearbox, it was my choise, i just wanted newer version, so it was from my wallet. As newer c7 have problem with chain noise and there is tsb also, but for high milage cars this sw update did not work. So its up to you, probably after adaption and oilcahnge if nothing improves, you may try tsb also.
    Oct 06 2016
    There is a noticeable change after adaptation clear!!! Going to drive it for a bit to check it out but its much smoother.
    I think I'll skip the TSB for now and see how this plays out. I might just be getting lucky.
    Oct 21 2012
    Earth...
    Few links:
    http://www.audizine.com/forum/showth...ission-Issues?
    http://www.audizine.com/forum/showth...ssion-Dragging
    And if google translate is not a enemy, nice write-up about adaption process:
    http://www.motor-talk.de/forum/tiptr...79.html?page=1
    Sent from my LG-D955 using Tapatalk
    Oct 06 2016
    Few links:
    Cheers!
    I don't think I want to fork over the cash to change my transmission fluid just yet. Just spent $900 on a carbon cleaning. Thanks for the german link, I understood a decent bit but honestly, my transmission is so much smoother now... I don't even think I need to do anything.
    Also, the component protection was gone after I got it back from the dealer! Woohoo!
