    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    N75-WG Lines 6mm ID... Is this okay?
    I've been having problems trying to track down some high RPM boost surging and am trying to figure out if my N75 control lines are too big. When I swapped my turbo out, I also changed the original lines with ones that had a 6mm ID. I can't remember how big the original lines were...
    While I'm in there poking around today, I'm going to be changing all of my check valves (found a few that were bypassing) and changing my pre-cat O2 sensor (It's 160k miles old). Just want to know if I should change my N75 lines out too.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    6mm seems a little large for the nipple on the wastegate actuator. The stock WG lines are tapered to accomodate for this.
    The "best" way to determine if 6mm is too large is to perform a boost leak test... this will tell you if air is leaking between the line and WG actuator nipple.
    Also a boost leak test will tell you if you have any boost leaks contributing to you boost issue, and if any check valves are bad.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Fry Sauce, UT
    No leaks with a boost leak test. Replaced all the check valves and now my idle sits at a solid -21 inHg (used to sit between -19 and -20).
    So as long as I'm not leaking from the WG lines they should be alright? The slightly larger ID lines shouldn't cause boost control issues?
    - Steve
    NKAWTG
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    No it should not matter. The wastgate is controlled by pressure, not volume.
    Fry Sauce, UT
    Sounds good! I was only thinking along the lines of a hydraulic system... use a line that is too large and you can end up with excessive pressure drops when the system is under load. Got me thinking that it might be contributing to my overboost condition. Overthinking it!
    - Steve
    NKAWTG
