Results 1 to 16 of 16
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Any factory audi or vw sway bars considered an upgrade over 01 5qm?
    Im blessed to have several foreign car junkyards local to me that are pretty well stocked with vws, volvo, audis of all years. Any sway bars considered an upgrade over factory? Can I just measure length and sway bar width off any car and swap into my 01 if I replace the bushings?
    Not paying $200 each for eibach when they are $10 each at the yard.
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Dec 10 2013
    Borden, Ontario, Canada
    Sport package cars have the S4 sway bars, so look for those. You can also use Subaru sway bar end links in the front. They're half the price of a performance aftermarket one
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jun 12 2008
    Allentown PA
    Thank you sir! how can i differentiate sport package from non? 3 spoke wheel with volume control buttons?
    Which model subaru end links? ordering now.
    Established Member Two Rings czum09's Avatar
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    02-07 Wrx end links will fit the front, aftermarket like whiteline. Rear end links can be upgraded to Meyle HD.
    Dec 10 2013
    Quote Originally Posted by 4A Play View Post
    Look at a scrapper and search the cars for red struts. The sport steering wheels aren't an indication of sport package, because the steering wheel is it's own $150 option back in the day
    Quote Originally Posted by czum09 View Post
    IG: 24_et
    Sold:
    RIP:
    Established Member Two Rings clause$'s Avatar
    Jan 26 2015
    Mammoth Lakes, CA
    Go big or go home. 034 vs sport sway bar.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    X2 on 034 rear with reinforcement brackets. Most track cars use a non sport A4 front sway with a large rear, i.e. The 034 one. I have that set up with Mahle HD rear end links and I love the set up. Just autoX'd the car last weekend and didn't feel any understeer. Did 3 laps dry and didn't get any and 3 lap wet and had the rear come out a little. This was my first autoX too. Hope this helps.
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    That 034 bar is awesome. I NEED it.
    Jan 26 2015
    Mammoth Lakes, CA
    My car has zero understeer now on the stiffest setting. You have to be careful though because the rear end will come around the second you push it too far.
    Jun 12 2008
    Allentown PA
    So if I bought my car used, with coilovers, how would I know if it had sport sway bars? Circumference measurement? Please don't tell me mm. I won't have a caliper in the junkyard lol
    Jun 12 2008
    Allentown PA
    I need more details on this stuff. I can weld pretty good and have made adjustable toe bars/ camber plates before.
    If I could get some clear pics and measurements I could fab up some stuff.
    So if I can find a truck sway bar set with eyelet to eyelet the same as an a4 factory bar, any thickness over factory is an upgrade?
    Oct 10 2013
    State College PA
    The 034 is 25.4 mm. 1 in. The nuespeed is 19 mm I think.
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    I have a front sport sway bar I will sell, if you need it.
    Oct 10 2013
    State College PA
    Run a stock front. A stiffer front will cause more understeer
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Go get an 034 rear sway bar, you wont be dissapointed. The resale value is always there as they are super high demand.
    I had abunch of understeer autox n with 034 rsb. lol. I think this run my tire pressure was too high for the super hot weather/pavement. I did drift it afew times though dry pavement. Davd you on k03/stock suspention?
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 10 2013
    State College PA
    Yea, stock suspenssion with kompresd stage 2. Just the RSB. Tire pressure was set at 40psi, way to high. It was my first autoX ever. Learned a lot last weekend. Might be running this Sunday. It should be dry and I'm going to have the tires around 30-32. Just watched your video. Looks great man.
