Results 1 to 11 of 11
    Feb 06 2013
    WV
    Building 06A engine, what should be done while it's apart?
    Car is going next week to have the engine pulled and will be rebuilt with a stroker setup and a 6758 efr aiming for 350awhp. I am wondering what all should be swapped while the engine is out. I am doing a press fit timing gear, solid mechanical timing belt setup, all new bolts (most ARP), new belts, oil pump, and water pump. I am wondering if there is anything I am missing.
    Suggestions?
    Thanks
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    May 17 2014
    Raleigh, NC
    I would freshen any rubber you can get your hands on. Toss all new gaskets in the head, half moonn seal, tensioner gasket,VC gasket.
    I would also take this time to clean up and straighten up the engine bay
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    It's all pretty obvious, but I would get a new oil chain tensioner too.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Are you completely set on the manual timing belt tensioner? If yours is a late AWM (maybe early AWM will work too) you can switch to the new style non-hydraulic Litens tensioner. Better than the old-style hydraulic damper because well, it doesn't have the hydraulic damper to fail. This also makes installation much easier. I put one on the AMB in my B6 a few months back, but it's the same as the AWM.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Feb 06 2013
    WV
    Metal man can you send me a link?
    Dec 05 2007
    I am 350whp butt dyno and no need for stroker for this. If you want extra tq and earlier spool, that can all be done with a tune. So this means money to save on a lot of parts, inluding pistons. I run aeb pistons on an awm block. Rods are Brute, but RPM rods (believe this is brand) seem to be the new cheap reliable way to go. S4 guys have been running them ever since the discover better than sliced bread...to Audi heads.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Blauparts has info about it on their site:
    http://news.blauparts.com/20140708-p...t-kit-1-8t-awm
    I bought the timing belt kit for my B6 from them (and for my B5 as well, but it was 3 years ago before the Litens tensioner update).
    These parts can be purchased separately also. I have P/Ns but would have to dig them up.
    Feb 06 2013
    WV
    Don't ask but I currently have 4 sets of pistons; stroker wiseco 82mm, wiseco stock stroke 82mm, stock aeb pistons nib, and je 81.5mm for stock stroke. Also already have the stroker crank but it depends on what the engine looks like on the inside. May go easy route and stuff aeb and forged rods in. The rpm rods look identical too Max's peed rods, which I have as well.
    I just want the goods before this deal starts so it's done as quick as possible. Don't want to a miss a thing.
    Dec 05 2007
    I personally only reused the main caps and oil squirters. Everything else new, including crank journals polished. Reused oil pump chain only because I somehow misplaced brand new one ordered. But a little stretch over the years was the only concern where the new chain tensioner compensated. But everything else replaced. Instead of a hot tank, with short block upside down I put brake fluid down each oil galley. Forgot where it flowed out, but that let me know it was clear.
    Every gasket and seal brand new. No need to spend double or more for the same end result. But you are a machinist, and have all at your disposal. So, new parts and basically get it done. Specs needed for building internals is in the Haynes manual. One thing, JE specs are wrong. This was discovered by B6 guys who ended up with piston slap, so I want to say piston to wall clearances were inaccurate. This was for 83mm pistons, but still something you may want to investigate for your overbored ones.
    Feb 06 2013
    WV
    I bought the JE since I got a good deal on them but I would let them go for a smoking deal of $350, if anyone is interested.
    When I asked what all should be replaced I was really wondering if there is small things that needed done but is overlooked. Here is what I am doing,
    All new gaskets Elring
    New water pump
    Oil pump, chain, tensioner
    Pistons
    Forged rods
    ARP head bolts, crank bolt, cam bolt
    New main bolts
    Press fit crank gear
    Mechanical timing belt tensioner
    RAI timing belt
    New bearings Calico
    Supertech exhaust valves, supertech retainers, supertech intake Springs
    New hydro lifters
    All new belts
    Clutch
    I am thinking of getting a new oil cooler as well. Really looking for an ie intake cam as well.
    I am wanting to go with the stroker setup in case I grow out of the 6758 efr.
    Dec 05 2007
    I used all new parts. Not a big kit fan. Ordered Gates belt elsewhere and put my own kit together. Of course new parts. And use the OEM wp with plastic impeller or Graf brand. Bad batch of Geba running around claiming motors. As for lifters, those too if building a head. Elring hg and arp head bolts. Also running IE press fit gear. With that gear, no need for arp crank bolt. OEM will do just fine. Or arp with dowel pins.
