Results 1 to 9 of 9
    Jan 24 2010
    Paramus,NJ USA
    Question SPA Turbo clone manifold fitment???
    Hey guys,
    I purchased a spa turbo manifold clone.Top mount for t3/t4 turbos.TMA04 The manifold fits over the studs but hits the cylinder head on the top studs.Wondering if anyone else has had fitment issues??Or do I need to remove the studs or simply have teh top of the flange milled a few mm to have clearance so it can be bolted up???
    I know this is a clone manifold.It will get me by for now.Just wondering if theres something I'm missing when it comes to fitting the manifold??
    Ziddy Autowerks
    Saint Cloud, Fl
    Do you have a picture of what you're talking about ? Mine fit properly
    instagram ------------> low_enforcement
    Jan 24 2010
    Paramus,NJ USA
    It looks like the top of the manifold doesn't clear the cylinder head??Or do I need to remove the studs and then reinstall them???
    Ziddy Autowerks
    Jan 24 2010
    Paramus,NJ USA
    Anyone???
    Ziddy Autowerks
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    I've heard about some aftermarket manifolds that have this issue. The solution is to simply trim the part of the manifold which contacts the head. Even FrankenTurbo manifolds you can tell the castings would have the same issue but they machined off the excess.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by MetalMan View Post
    Yeah that what I was thinking.Just wanted to make sure before I went that route.
    Ziddy Autowerks
    Dec 05 2007
    Grind and cut away as necessary or resell. Don't see any other way around it. You can mark off what needs to be done and have a machine shop do it also.
    Jan 24 2010
    Paramus,NJ USA
    I think thats what i'll do there is a machine shop right in town that hould be able to do it on one of their machines or a water jet if need be.
    Ziddy Autowerks
    Dec 05 2007
    Smart choice. One wrong slip doing it yourself and it can crack, let alone hurt yourself quite terribly too if things went awry.
