Results 1 to 18 of 18
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Cycling the coolant pump?
    Saw a thread here on cycling the coolant pump for the supercharger (something like opening the hodd, then opening and closing the drivers door). Tried that but it didn't work. Is it possible on the B8.5 to cycle the pump without turning over the motor?
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Mar 21 2015
    You can wire it to a switch and turn it on in the cabin whenever you want.
    Sep 20 2006
    MD
    Was looking for a "factory" mechanism for doing this. Similar to a BMW where you do a set of functions on the car to cycle the water pump in order to purge air out of the coolant loop. Figured there was some way via VAGCOM or similar.
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    my AMS pump cycles whenever I touch the door handle, unlock the car, move the seat from the inside, auto shuts off after 1-2 minutes if the car doesn't start or whatever
    it's actually wired into same fuse set and harness as the stock coolant pump
    i "want to beleive" that the stock one does run and prime in addition to the AMS because it's wired in with the factory harness , but you just don't hear it since its' so quiet?
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I have AMS and every time I open a door or the trunk it turns on for a bit then turns off.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Sep 20 2006
    MD
    You all own B8s, correct? I'm wondering if the B8.5 is different somehow
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by RLB6 View Post
    Don't think there is a way to manually cycle the pump on either B8 or B8.5. You can rewire it to come on with the ignition and run all the time when the ignition is on.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    On the B8.5 the pump turns on whenever the car wakes (open a door or the trunk, unlock the car, etc.). The factory pump is almost silent. My AMS pump is wired into the factory pump and you can hear it whenever the car wakes. You can just open and close the door and it will cycle.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Jan 04 2013
    Phoenix, az
    Sounds like B8 and B8.5 are the same.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    all of the aftermarket pumps will trigger when the power source provides power to wake up any of the OEM modules (ecu etc etc...). Although each are "plug-n-play" into the OEM harness, there is also a separate power wire that is wired directly to the power source behind the cowl.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Established Member Two Rings Woodybangs's Avatar
    Jan 08 2016
    MI
    Can tuners change it? On my e55 the tuners would change the programming for it to run all the time.
    Current: Audi 2018 S6 - DS1
    Former: Audi 2010 S4 DSG prestige - EPL Stage I + DSG tune | AWE intake | Neuspeed exhaust + non-resonated downpipes
    2006 Wrx STI stage II 330hp 315tq | 2005 E55 Eurocharged tune, pulley, headers - Highway monster
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Quote Originally Posted by Woodybangs View Post
    Yes, and yours did =)
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by Tony@EPL View Post
    That's cool it can be changed in the ecu instead of cutting wires...can you shoot me a pm and lmk under what pid that options located? Thanks!
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Sep 20 2006
    MD
    If there is an option to cycle it via VAGCOM, let me know.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Why would you (or the factory) want to cycle the coolant pump when you open the door???
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by BlownOne View Post
    +1 for the info.
    Geoff
    Jan 04 2013
    Phoenix, az
    If your sitting at the drag strip you want to keep the coolant cycling through the SC to help cool it off. That is why a lot of guys are doing it.
    Sep 20 2006
    MD
    Quote Originally Posted by S4'ed View Post
    As a means to purge air our of the coolant loop. I didn't have access to a vacuum fill system.
