Results 1 to 10 of 10
    Established Member Two Rings Ryanroland's Avatar
    Mar 11 2015
    Honda S2000
    California
    Did I miss something?
    So I decided to tackle a few projects on my days off.
    1. Oil change (no biggie, done it several times on this car
    2. Rear diff fluid change (sounded super easy)
    3. Install H&R springs over existing struts (I've done this a few times on hondas)
    So first problem was with the rear differential. As I'm adding my 1.9L (per JHM website, but some say Tips only take 1.5) I only get to 1.2-1.3 maybe, and my differential starts spewing out more than a little bit. Not like a hey you've reached the limit, so let me overflow just that little extra. It was like I gave it food poisoning and it was trying to empty all of its contents. Baffled on that part
    Second I'm only on my first corner of the spring install and I can't keep the strut from spinning to tighten down the top nut. New spring already on. Any suggestions? I'm pretty frustrated considering all the videos and write ups kind of skip past this step like it should be no big deal
    2006 S4 Brilliant Black | Europaparts cat back exhaust | H&R Springs | B8 S4 19" Peelers | I really need more mods to make this look cool
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Diff- are you sure you drained all of the old fluid? And is car level?
    Strut - ive grabbed it with vise grip and was able to tighten it down
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jan 25 2012
    Fort Collins, CO
    ECS has the most unbelievably detailed install manual for H&R springs if you don't already have it in front of you.
    Did you overlook the hex on the shaft of the strut? Page 22.
    http://bd8ba3c866c8cbc330ab-7b26c6f3...stallation.pdf
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Quote Originally Posted by Ryanroland View Post
    This write up (top search result...) goes into some decent details on that top nut issue:
    http://www.audizine.com/forum/showth...=1#post6380229
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    that seems normal. i've changed my B7's twice, and i've never fit the required amount in. B6s might use even less.
    - emilio
    Mar 11 2015
    Honda S2000
    California
    Quote Originally Posted by Lucca M View Post
    Yeah four jack stands equal height
    Quote Originally Posted by tmorgan4 View Post
    Nice reference. Did not see that (on ecs, I saw the hex but didn't have a wrench that could get in there)
    Quote Originally Posted by badger. View Post
    That write up is the best one I've seen. I wonder why it's not in the DIY sticky. So it looks like a quick trip (again) to harbor freight for the open ended sockets and I'm golden.
    So any idea on the fluid level? I can't exactly get my big head up there to check. And I let it drain for about 15 minutes and both plugs were out. It wasn't even dripping slightly so I assume it's out
    Mar 11 2015
    Honda S2000
    California
    Fronts all done :fist pump: now before I start the back, I'd like to finish the rear diff fluid. If it's spilling out do you think it's safe to say it's full?
    Mar 11 2015
    Honda S2000
    California
    I'm embarrassed to admit, most of my struggles are coming from not paying attention to the details. Fronts were a struggle because of the UCA and the hex nut on top of the strut. Now I'm struggling with the rear. It took a lot more struggle than any DIY or video showed. I removed the sub frame bolt to the rear of the strut but did not notice people were saying to loosen two bolts per side. Found the bolt I did not know to loosen and I suspect it will make the whole process way easier. Especially since it's right next to the spring and that is the place with the least amount of movement where I need the most amount of movement.
    Oh well, back at it again tomorrow. I learn from one side and the second side gets way easier
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    If you metered the fluid while the car is level, it will be fine.
    Mar 11 2015
    Honda S2000
    California
    Quote Originally Posted by S4Bennett View Post
    Yeah I was thinking maybe if you just jack up the rear it will allow the fluid to go towards the front of the rear diff and allow for more fluid. Hopefully that is not necessary
