Results 1 to 3 of 3
Thread: Clutch issue
    Senior Member Three Rings Moose88x's Avatar
    Apr 13 2016
    B9 SQ5
    Ohio
    Clutch issue
    I've spent the past couple days researching on here but can't exactly pin point the issue. I had a eurocode stage iii clutch installed this past week and needless to say I was a bit giddy because my stock clutch finally kicked the bucket on apr stage 2. Well anyway when I go to take my car home I engage the clutch, which is lower than oem, however when I disengage the clutch the top half is very slow to spring back. If I were to pull my foot off of the pedal, it will slap my foot? Sometimes the pedal will stick as well at the bottom. The other issue im having is trying to shift around 4-5000 sometimes it will not go into gear and i have to almost double pump the clutch and it will then go in smooth. Based upon my reading I'm thinking slave cylinder or the shop didn't bleed my clutch correctly. Any advice would be awesome.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Yes, sounds like there's still air in the line to me.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    I think AudiS4B8 has had this issue, I'd ask him. That would drive me insane for sure.
