Results 1 to 15 of 15
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    2007 Audi RS4 - Misano red
    * Sale Pending *
    This ad is meant to not waste mine or yours's time and its objective is to be as detailed as possible. Which is why i have included all service history from Day one on this car and have provided a walkaround video of it as well. Please read through, your questions will likely be answered below. If (after reading the information below and watching the video) you are interested in the car, send me a message.
    This is a US Spec car that is located in Calgary, Alberta, Canada. Since its an american car, it will not have any import fees and you shouldn't have any issues bringing it over to US.
    Here is a list of key features about this specific RS4:
    - OEM Titanium RS4 wheels (recently refinished with new tires)
    - Trim wrapped Gloss black
    - Clean title no accidents, no damage, clean carproof.
    - FCP Euro front upper control arms
    - 034 motorsports Density line street transmission mount
    - 034 motorsports differential inserts
    - ECS tuning rear differential mount
    - K&N high flow air filter
    - Brembo 2 piece cross-drilled front rotors (OEM)
    - TRW brake pads (OEM)
    - 10mm H&R hubcentric/wheelcentric spacers in front
    - 15mm ECS tuning hubcentric/wheelcentric spacers in rear
    - ECS tuning steel brake lines
    - OEM Audi rear rotors
    - OEM Audi brake pads
    - ATE super blue DOT 4 brake fluid
    - Ziza LED license plate conversion assemblies
    - Magnaflow 2.5” X-pipe. Works with stock exhaust valves via the S button.
    - OEM fuel filter
    - Full decarb of engine at Glenmore Audi along with new:
    o OEM intake manifold
    o OEM fuel injectors with gaskets and rings
    o PCV valve
    - Transmission serviced with Motul 300 full synthetic gear oil
    - Engine oil service with OEM filter and Motul Xcess full synthetic
    14,000 km (Glenmore Audi):
    Faulty rear rotors and brake pads replaced
    Faulty/warped front rotors replaced
    23,374 km (Glenmore Audi):
    Completed 25,000 km service at. Oil service, filters, system inspections etc
    Installed new winter mats
    Replaced loose/faulty left side mirror housing and entire mirror base with new parts
    30,199 km (Glenmore Audi):
    Performed 40,000 km service. New oil, filters, lubing joints, toping up all fluids and all system inspections. Done at Glenmore Audi.
    Wheel alignment done
    Serviced driver’s side window motor and window seal
    31,322 km (Glenmore Audi) :
    Installed new OEM front bumper
    37,711 km (Glenmore Audi):
    Re-aimed headlights as they were aimed too low
    Mounted and balanced winter tires
    Serviced engine with new oil and filter
    Replaced wiper blades
    42,624 km (Glenmore Audi):
    Performed 55,000 kms service. New oil, fluids, all system inspections completed.
    Replaced drivers side fog light assembly
    Inspected wheel bearings
    55,555 km (Glenmore Audi):
    Performed recall 53b3. Battery tray.
    Rebalanced and mounted new tires
    Dynamic ride control recall performed. All suspension components replaced with new updated ones as per Audi recall.
    Ignition coils recall performed. Replaced coils with new updated ones.
    Performed 70,000 km service. Replaced oil/filter and all other fluids. Inspection of all systems.
    60,457 km (Glenmore Audi) :
    Replaced engine oil/filter. Topped up all fluids.
    Mounted and balanced summer tires
    Performed 4 wheel alignment
    Flushed brake system and drained excess fluid
    69,867 km (Glenmore Audi):
    Performed 85,000 km service. New oil/filter. Check/replaced all fluids and inspected all systems. Adjusted headlight system. Replaced pollen/air filters
    Replaced spark plugs
    Replaced wipers and pivots. Cleaned and aimed jets
    Mounted and balanced wheels
    Removed and replaced right outer tie rod end
    76,494 km (Glenmore Audi):
    Replaced battery
    Mounted and balanced tires on 19” wheels
    80,463 km (Glenmore Audi):
    Mounted and balanced new tires
    Performed wheel alignment
    85,207 km (Glenmore Audi):
    Installed winter tires. Balanced.
    98,352 km (Glenmore Audi):
    Performed 100,000 km service. New oil/filter. Replaced filters as needed. Topped up all fluids and inspected all vehicle systems.
    Installed and balanced summer tires
    103918 km (Glenmore Audi):
    General maintenance/inspection. New rear brakes needed. Front brakes at 30%
    111,114 km (Glenmore Audi):
    Performed 115,000 km service. Replaced all filters. Replaced oil. Inspected all systems and topped all fluids. Inspected ribbed belt and timing tensioners and pulleys
    Replaced rear brake pads and rotors
    111,150 km (Glenmore Audi):
    Found big slash on front tire. Replaced all 4 tires with new summers
    113,697 km (Glenmore Audi):
    Inspected intake manifold. Excessive carbon build up
    Replaced intake manifold and gaskets
    Replaced fuel injectors
    De-carbd engine and manifold area
    Replaced hoses with updates versions
    Replaced leaking PCV valve
    117,000 km (Garage Box):
    Replaced engine oil and filter with Motul Xcess
    Replaced transmission fluid with Motul gear oil 300
    Balanced and installed winter tires
    119,000 km (Minute muffler 32 ave):
    Installed Magnaflow X pipe
    121,000 km (Real Auto Pros):
    Replaced engine oil with Motul Xcess
    Replaced brembo front rotors and pads with new steel brake lines with race grade fluid.
    Replaced front upper control arms. Inspected lower control arms and tie rod assemblies. OK.
    Replaced seized steering knuckle assemblies
    Installed performance transmission mount
    Installed performance differential mount
    Installed performance differential inserts to stiffen up bushings
    Balanced and Installed Toyo Proxes T1 summer tires
    121,500 km (Eurospec) :
    4 wheel alignment and adjustment after control arms installed.
    122,000 km (Real Auto Pros):
    Replaced fuel filter
    Installed K&N high flow air filter
    Installed LED license plate assemblies
    122,500 km (Calgary autoworks):
    Wheels balanced on summer tires
    Inspected rotors and pads for deposits
    123,000 km:
    Installed carbon charcoal activated cabin air filter
    Installed H&R 10mm spacers in front
    Installed ECS tuning 15mm spacers in back
    125,000km
    Oil change with Motul Xcess/ OEM filter
    Air filter change with OEM flter
    128,000km
    RS4 titanium wheels installed
    275/30/19 all season Hercules tires installed
    130,000km
    Trim wrapped black
    Oil change with Motul Xcess and OEM filter
    Other things to know:
    Car had the front bumper resprayed and now has Suntek film installed on it. The rest of the front has the stock 3M film.
    A recent 2 stage polish/cut compound was applied and the paint was then sealed. Frequent applications of Collonite 845 wax thereafter.
    Interior leather was treated and cleaned recently.
    The car has some decently heavy tint on the windows.
    Comes with 1 set of Audi rubber winter mats, 2 sets of summer mats.
    I have records and receipts for all parts/services on this car and can provide contacts for all mechanics who worked on it and the previous owner.
    WALKAROUND VIDEO:
    Mar 26 2015
    I thought RS4's are dailies nowadays lol... good lookin' RS4... good luck with the sale!
    Established Member Two Rings Iridium.'s Avatar
    Nov 07 2012
    Okanagan Valley
    I see in the Kijiji post that the timing chain, guides and tensioners were inspected. Obviously nothing was replaced at that time. Did Glenmore Audi give any indication that the guides and tensioners were wearing?
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by C-Lo View Post
    haha i was planning on dalying it but since I'll be in school for the next 4 years coming up, sadly i wont be able to keep her
    Sent from my SGH-I337M using Tapatalk
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by Iridium. View Post
    no they didn't a actually. i did speak to the the mechanic who worked on it and he said everything looked fine internally except for the massive carbon buildup which was rectified by a full decarb, new injectors, gaskets and a new intake manifold replaced by Audi. lol if someone looked at that bill they would think the whole engine got replaced haha
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    bump!
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    bumpppp fresh oil change
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    New info updated!
    Established Member Two Rings Vaks's Avatar
    Nov 20 2015
    Beautiful ride with amazing service list! Don't know how anyone hasn't picked this up yet.
    GLWS!
    Current:
    2013 Audi A4
    AudiTrueNorth | Ibis White | Quattro | RS Grille | RHO Plate | BlackVue | APR Carbonio Intake | GFB DV+ | KW V2 | AG Wheels
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by Vaks View Post
    GLWS!
    thanks! have a few offers in the making we ll see!
    Nov 20 2015
    Quote Originally Posted by skhan91 View Post
    Hard to come by owners who actually take care of their ride, and do not only regular maintenance but preventative maintenance like decarb, transmission fluid changes, etc. I would've definitely picked this up if I seen it about a year ago.
    Current:
    2013 Audi A4
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    thanks man. yea with cars like this it saves a lot of headaches to be up to date on all maintenance. plus its a rare audi! wont do it justice to neglect it ;)
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Bump! price reduced to $23K USD or $31k CAD
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    * Sale Pending *
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    SOLD
