Results 1 to 7 of 7
Thread: EGT temp
    Established Member Two Rings Siopao's Avatar
    Aug 22 2016
    2019 A7 2021 Q7 (wifey)
    Houston, TX
    EGT temp
    Hello all,
    Just picked up a P3 gauge. Wondering for those that have one what does your egt usually range in? Current mods revo stage 1 roc euro intake and awe track exhaust w/resonated down pipes.
    Senior Member Three Rings A4-B6's Avatar
    Nov 09 2009
    2011 S5 Prestige Briliant Blk/Pearl
    N.CALI
    Mine usually shows 1300-1500 or so. What are you seeing?
    SOLD
    Nogaro 2001.5 S4
    JHM built
    12.1 @116 MPH
    2011 S5 Prestige
    https://imgur.com/a/YKQww#0
    Fast Intentions exhaust, Euro tail lights, RS5 front grill w/fogs, JHM 382mm BBK, Lightweight disc x4, JHM tune, VOLK G2's, JHM Stage3 clutch, JHM Supercharger kit, JHM HFC's.
    Aug 22 2016
    Houston, TX
    Same range. Wondering if the heat has any correlation to proper air fuel ratio. Especially now with that service campaign for our cat being to sensitive. Also having a tune would egt be affected?
    2013 S5 | TSW Portier 20x10 |AWE track exhaust w/resonated dp | P3 gauge | Revo stage 1+| roc euro intake | Revo charge cooler package
    Nov 09 2009
    N.CALI
    In a way I'm glad to hear mine is inline with less modded car. Unfortunately I got the P3 after I was Supercharged.
    SOLD
    Nogaro 2001.5 S4
    JHM built
    12.1 @116 MPH
    2011 S5 Prestige
    Aug 22 2016
    Houston, TX
    Quote Originally Posted by A4-B6 View Post
    What are your other numbers your getting? Boost? IAT? What's your best time 0-60?
    Feb 15 2016
    Oak Lawn IL
    on my 2010 A5 2.0T with a 6spd manual my p3 guage says boost spikes to about 17-20 psi depending on the load and what gear im in and then tapers down to about 5psi as a approach redline. does that sound right for a stock 2.0T? my EGT are anywhere between 1250-1600 and today i seen IAT when moving at 60 in 6th gear where at about 80F when the outside temp was low 60F today. i am woundering how accurite these numbers are mainly the boost cause that seems really off to me.
    Aug 22 2016
    Houston, TX
    Quote Originally Posted by kpr478 View Post
    My ranges are pretty much where I'm at except my boost peaks around 13.6psi. Would the values of boost be different between a turbo and a supercharger?
