Price:
$500
Condition:
Used for about 17k miles. Have had the rear clunk noise (below 40mph) since new but perform perfectly.
Description:
Achtuning exclusive Gran Turismo suspension kits come with custom spring rates and proper shock valving designed to eliminate understeer in hard cornering. Ride quality remains high, while understeer is greatly reduced without the need for a rear roll bar by utilizing a heavier rate rear springs. By utilizing stiffer springs than competing kits in the sub $2,000 range with shocks specifically valved for a compliant ride, the Gran Turismo coilovers are perfect for street and track driving.
These kits combine user selectable height reduction, stiffer springs and properly matched shocks that will improve steering response, reduce body roll and reduce understeer.
Many drivers prefer to set the ride height exactly to their liking. That is why Vogtland GT3 coilovers are ride height adjustable. This adjustability will also allow for corner balancing if so desired.
- Fits Audi B5 A4 Quattro and B5 S4.
- Reduced body roll with excellent body control out of the box - no adjustment necessary.
- Progressive rear springs with a working rate of 675 lbs/in (at FULL compression they are 760 lbs/in).
- Height adjustable - 1.5" to 2.4" lower than stock.
- Height adjustment wrench included.
- Exclusive HDPE spring bushings.
- Made in Germany, ISO 9001 Certified and TÜV approved.
