Results 1 to 36 of 36
    Jun 12 2015
    CA
    New Q5/SQ5 Quarter-Mile Record 11.95 @ 113.61 (EPL)
    Last night I had a chance to get out to Sacramento Raceway and run a few passes in some terrific October DAs (+300). When I got there the place was packed because it was Corvette night. When I pulled into line, I randomly ran into the guys from JHM Motorsports who were there to run some of their shop cars. We had 30 minutes to kill before we could even do a dial-in run so we chopped it up. Sup fellas! I got to the strip with ¼ tank of gas and 41 PSI in my tires.
    When I finally did my dial in, I ran an 11.999 @ 113.64. My first time under 12 which was great! However it could have been better because I had a fuel shortage. On the second pass I ran a 12.005 @ 114.11. A faster trap speed, but slower ET due again to a fuel shortage I’ll get into in a second.
    The record pass was right before they closed at 9:30pm. The DA was right around +300. Because of the fuel shortage issues at the top of the RPM band, I decided to manually shift earlier, around 6500 in 3rd and 4th, and it ran a lot better. Not perfectly, but better than the first two runs. The result was the fastest ET and the slowest trap speed 11.950 @ 113.61 of the night. I took an in cabin video and posted it to YouTube (below). I know the slip is hard to read, so here are the splits:
    60ft: 1.772
    330ft: 4.986
    660ft: 7.660
    1/8 mph: 92.05
    1000ft: 9.976
    The fuel shortage issue is the same one the E85-blend guys on the S4 board are facing. E85 requires 50% more fuel volume compared to normal gas because it isn’t as efficient. The higher the RPM and gear, the higher the fuel requirement. Above 6500 RPM I can feel the car “top out”, and basically cruise instead of accelerate. The great news is the S4 guys have found a solution in the form of an inline booster which increases the fuel volume. This is fantastic because it will allow me to shift between 6900-7200, and run more E85, and less crappy California 91. The EPL tune is ready to provide the power; I just need to upgrade my hardware to allow it to do its thing.
    In addition to the 11.95, I also ran a 3.83 0-60 (VBox timed). I took a picture of the VBox app results since it had some other interesting numbers.
    Special thanks to Tony and Chris at EPL for working with me on the tune. We’re going to start working on more stuff for you guys, so stay tuned for even faster times.
    Happy boost season!
    2015 Q5 3.0T | EPL E85 | APR SC pulley | KI 194mm crank pulley | CTS Turbo intake | AMS Alpha cooler | EC headers | Milltek valvesonic exhaust | KW V3 coilovers | 034 X-brace | 034 Trans mounts | 034 Rear sway bar | 034 ACAs | Girodisc LW front rotors | JHM LW back rotors | HRE P104 21x9.5 | Michelin PSS 285/35/21 | Autotech HPFP
    11.788 @ 115.64mph [ KI 194 / APR 57.73 | 104 | -350 ft. D/A ]
    11.950 @ 113.61mph [ KI 194 / APR 57.73 | E85/91 | +300 ft. D/A ]
    0-60 in 3.71
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Impressive. . .most impressive.
    Veteran Member Three Rings rusq5's Avatar
    Mar 27 2015
    SF Bay Area
    Wow. Great job Colby!
    Tony and Chris are really showing some amazing stuff with that tune.
    How many vette owners did you smoke? Hah
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    Veteran Member Three Rings cmoore86's Avatar
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    Nice work! I am just on stage 1 with EPL for a few days now. Nice to see how far this can go when pushed!
    2018 Audi [] SQ5: Navarra Blue | BBS | AWE | 034 |
    Sold - 2015 Audi RS5: Sepang Blue My Sepang Blue RS5
    Sold - 2015 Audi SQ5: Sepang Blue cmoore86 2015 SQ5
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    Nice work. EPL is definitely making power.
    I hope to join the 11 sec "heavy weight" club soon.
    Sent from my SAMSUNG-SM-N915A using Tapatalk
    Jun 12 2015
    CA
    Yeah thanks guys this thing pulls hard off the line. Some of my launches are a full 1.0 G-force of push back into my seat, as recorded by the VBox.
    nsantos - we're definitely the heavy weight club. It's the equivalent of the S4 guys packing their cars full of their buddies, and running 11s. Haha!
    0-60 in 3.71
    Mar 28 2013
    Chicago
    Congrats Colby! You've been knocking on the door for a while now. Nice to see you break through
    2013 Q5 3.0T Phantom/Black
    APR Stage2 | APR CPS | 034 Inlet Hose | ECS 12.5/20mm | 255/50-19 DWS06 | 034 Inserts | P3 | ...
    2020 MB GLC63, Black,
    2019 BMW M2 Competition, Black, 6MT (sold)
    Mar 27 2015
    SF Bay Area
    Quote Originally Posted by ntsantos View Post
    Same here.
    Time to start a norcal group for fast q5s.
    -Rusty
    IG: @grn_rs6
    Sep 28 2010
    NW NC / DE
    Those Milltek pipes did wonders!!
    Congrats Colby
    Jun 12 2015
    CA
    Congrats Colby
    Did you hear those things growl?! That's from inside the car with the windows up. Nasty!
    0-60 in 3.71
    Jun 12 2015
    CA
    Quote Originally Posted by BlackSVT View Post
    Thanks man! Yeah I hooked up with EPL in April. I went to the track for the first time in June and ran a 12.45. Over the next 3-4 months we've worked on the tune, and the times have dropped consistently since then: 12.45, 12.31, 12.29, 12.19, 12.00, 11.95. During that 3-4 months, there was only one time when I went to the strip and I didn't set a new PR. And that trip was just as helpful as the others because that's when I learned that I needed to blend some gas with the E85.
    Now that I think about it, I should probably ask Sacramento Raceway if they have a season pass.
    0-60 in 3.71
    Jun 12 2015
    CA
    Quote Originally Posted by rusq5 View Post
    Same here.
    No doubt! I hope you've gotten some time at the strip. Looking forward to kicking it next month.
    0-60 in 3.71
    Mar 27 2015
    SF Bay Area
    Quote Originally Posted by colby7 View Post
    Not yet. Slammed with work, I'm just hoping I'll have the AMS cooler and test pipes on by Nov.
    Trying to line up the 189mm pulley right now. Maybe both can go on this month.
    -Rusty
    IG: @grn_rs6
    Deactivated Four Rings
    Jun 23 2011
    I can check, but pretty sure the Fluidampr 189s are in stock.
    Veteran Member Three Rings Adplaya's Avatar
    Apr 25 2015
    TEXAS
    3.8sec 0-60!?!?!?! Insane numbers. I have been looking to tune soon, as I found a dealership willing to accept a tuned car.. This is swaying me towards EPL for sure.
    Mythos Black on Black SQ5
    H&R springs - CF Mirrors - Eurocode Transmission Mount - Black Diamond AWE Touring Exhaust - Hardwired V1 (for the haters) - LaminX
    - 15/20 Spulen Spacers - Thinkware F750 2CH DashCam - 034 Rear Sway Bar and End Links
    Senior Member Three Rings rgvsq5's Avatar
    Feb 03 2015
    Texas
    Would times be slower or faster if exact same setup was in an SQ5? Different transmission?
    SQ5 | APR Stage 2+ : APR CPS v2 : AWE : Bilstein : H&R : ECS Tuning : 034Motorsport : P3Cars : Adam's Rotors : E-Code : XPEL
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Great results!
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    geez thats impressive, congrats! and the sound
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Jul 10 2014
    Congrats Colby
    Yeh she's sounds NUTZ! GREAT WORK MAN!!!!!
    May 31 2016
    Mexico
    Quote Originally Posted by rgvsq5 View Post
    I could be wrong, but from reading the thread here (SQ5-0-60-amp-1-4-Mile-Times), it seems the SQ5 needs an additional gear change to reach the 1320, hence possibly slowing it down.
    Jun 23 2011
    I think the Q5 and SQ5 have the same trans, but different gearing
    Mar 27 2015
    SF Bay Area
    Slower, SQ5 has taller gearing.
    -Rusty
    IG: @grn_rs6
    Mar 28 2013
    Chicago
    Quote Originally Posted by Q5OnTheMove View Post
    I'm pretty sure both the Q5 and SQ5 need that last shift when Stage2+ (108+ trap speeds). All current info shows the Q5 to have 3.204:1 final drive and the SQ5 3.076:1. There seems to be some info showing that the SQ may have had the 3.204 gearing in '14, and there were some early, wrong typos showing 3.760:1, but it's all been tough to verify.
    In any case, If you watch colby's Q5 run, he's well into 5th at ~5800 rpm by the end of the run so there was no way to stretch 4th out. My "thinking out loud" on the SQ5's taller gearing was that it might be enough to eek out 4th to the traps, but gary simpson said in the thread u reference that he still needed to shift ~25' from the end.
    Bottom line seems to be, even with the supposed gearing advantage of the Q5 over the SQ5, since they both need that last 4th-->5th there's no real advantage there for either. I am curious if similarly tuned Q5 and SQ5 show a better 60' time for the Q5, but it seems like high 1.7s, low 1.8s is possible on both. I dunno 3.076/3.204 is only3-4% difference so it may never make as big a difference as track conditions, driver, etc
    Jan 23 2013
    CO
    Macan Turbo owners are peeing their pants!
    2018 Audi TT RS Ara Blue
    PAST: 2017 BMW X6M
    PAST: 2015 Daytona Gray Pearl SQ5, Tech, Lux, 21s
    PAST: 2017 Porsche 911 Miami Blue Carrera 4S
    PAST: 2015 Lexus RCF
    PAST: 2013 Phantom Black Pearl RS5, MMI, Titanium, DA
    PAST: 2011 Lexus IS-F
    PAST: 2010 Infiniti G37x
    PAST: 2009 Subaru Spec B
    Jun 12 2015
    CA
    Quote Originally Posted by Lavoisier View Post
    Haha well it's true the Macan crew haven't gone this fast yet. But I know I guy with one who's a hell of a driver, and I'm confident he will mod his out and put me in his rear view mirror.
    0-60 in 3.71
    Jun 12 2015
    CA
    I think with a TCU tune both the Q5 and SQ5 could make it in 4th gear. The TCU tune could adjust the redline in "S" mode to 6900 or even 7200 rpms. That would allow us to stay in our gears a little longer. Gary's SQ5 was shifting from 1-2 and 2-3 at 6500 rpms, and he was missing the finish line by just 25 feet. With a TCU tune, those shifts could all happen at 6900 rpms, and SQ5s would easily make it in 4th gear. The Q5s might need to go with a 7200 rpm TCU tune in order to finish in 4th gear.
    Because the Q5 has a higher final gear ratio, it produces more torque, and should have better 60ft times. My best 60ft so far is 1.768. I don't know of any SQ5s that have done a 1.7x.
    The other day I was logging data on a back road pull, and one of the items I logged with my VCDS was engine torque. I had readings over 700nm. That converts to over 515 ft-lbs of torque.
    0-60 in 3.71
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    sign me up for epl
    Jun 23 2011
    You rang?
    Senior Member Two Rings LW3's Avatar
    Feb 09 2014
    NC
    14 RS7 | 16 SQ5- Sold
    Feb 03 2015
    Texas
    What VBOX do you have? If you're feeling really nice, link to it?
    Jun 12 2015
    CA
    Vbox sport: http://www.vboxmotorsport.co.uk/inde...ers/vbox-sport
    It's accurate with .5%. That means my 3.83 reading is within 3.75-3.91.
    0-60 in 3.71
    Jun 12 2015
    CA
    New update: Tony at EPL made me a race file over the last week, and I took it out to the strip last night to do some initial logging. Typically what we do is start with a conservative file, and do iterative file updates to dial it in from there. All five passes last night were in the 11s. My fastest was 11.895 @ 114.07, including a 3.79 0-60.
    0-60 in 3.71
    Established Member Two Rings drivenagain's Avatar
    Sep 05 2016
    MD
    on straight 104?
    2013 Q5 3.0T | 57mm | 194mm | EPL DP Tune | Injen Intake
    2009 Aprilia Dorsoduro | TI Fuel Exhaust
    Jun 23 2011
    Quote Originally Posted by drivenagain View Post
    on straight 104?
    Yes straight 104
    Mar 27 2015
    SF Bay Area
    Quote Originally Posted by Chris@EPL View Post
    Yes straight 104
    I'm interested now. Do you still need new HPFP for 100/104 tunes? I know fueling is an issue.
    -Rusty
    IG: @grn_rs6
    Jun 23 2011
    The HPFP kit is only needed for the stage 2 or higher E85 tunes.
