Results 1 to 6 of 6
    May 29 2016
    Illinois
    Golf r shocks fit a3??
    Would 2016 Golf R shocks work on a 2016 A3 with S3 springs? I'm trying for an OEM setup and I understand you may recommend aftermarket for performance but I would like to know if anyone has insight into the compatibility. It looks like aftermarket shocks are spec'd for all MBQ models with IRS but I'm trying to avoid unforseen issues. Thank you for your help.
    Aug 08 2016
    Check the Audi/Vw part numbers if they match they fit
    Apr 12 2016
    North America
    Quote Originally Posted by Michaelp4283 View Post
    Doesn't the Golf R have the VW-equivalent of mag ride?
    If not, I don't see why they wouldn't fit as the A3, S3, Golf, GTI, and Golf R all use the same aftermarket shocks.
    May 29 2016
    Illinois
    Audi and VW seem to use different numbers for everything, so how do I go about doing this?
    Nov 17 2014
    San Francisco, CA
    Yes they fit, same platform, only difference in some cases is spring rates. I'd compare those more than anything.
    Sent from my SM-N910V using Tapatalk
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    The magnetic shocks on the R function differently than the ones in the S3.
    http://www.my-gti.com/2653/volkswage...n-and-function
    http://www.audi-technology-portal.de...gnetic-ride_en
