Results 1 to 8 of 8
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Alignment Question?!?!
    Hey guys quick question I baught a 2005 galant to sell and make profit. But i know we have some serious experts in alignment here in the zine. So i'll ask, i changed the tie rods on the car today and sway bar endlinks. I did my best to keep the alignment straight which is was but now my steering is a little to the right. Not a lot but is noticeble. So i would have to adjust my tie rods. I have an idea how but which do i have to lengthen and which to shorten? To make the wheel straight again?
    Ivan
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    You will have to adjust both inner tie rods equally if you dont want to mess up your current total toe. Your wheels are actually pointed left, which explains why you have to turn the wheel to the right to even things out. Break loose the nut and twist your driver side inner tie rod 1 turn counter clockwise. Then do the adjustment on the right side but turn the inner tie rod clockwise 1 turn. Now i dont know how much your steering is off, but I would probably start off with a small amount. Guess and check.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Aug 20 2013
    Miami
    Quote Originally Posted by Denio24 View Post
    no my wheel is pointed to the right so i have to turn it to the left to even things out.
    Ivan
    Senior Member Two Rings vwgtivr6's Avatar
    Dec 21 2010
    2015 S4
    SF
    If you set your steering wheel straight, the car turns left? Shorten the left tie rod and lengthen the right.
    Better yet, bring it to a shop and get a proper alignment.
    Your steering wheel may be straight but the total toe may be off and it will ruin the tires.
    Aug 20 2013
    Miami
    Quote Originally Posted by vwgtivr6 View Post
    is a car for sale brotha. i already spend $3oo on it. or else i would make no profit lol. so i'm trying to get it straight.
    Ivan
    Apr 24 2016
    California
    Quote Originally Posted by dalmation53 View Post
    Two wheel alignment is gonna cost you $50. If $350 eats up your profits on this car then it was a bad investment to begin with.
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Aug 20 2013
    Miami
    $50 for alignment? Lol here in orlando fl is like $100 to $150. If i would find a $50 alignment i would save the trouble of doing it myself
    Sent from my C5306 using Tapatalk
    Ivan
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Just sell the car as is and let the buyer know it needs an alignment. Most people don't really care because it's cheap and they'll most likely get it done anyway.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
