Results 1 to 16 of 16
    Junior Member Two Rings Blythiano's Avatar
    Sep 24 2014
    Portland, OR
    iPhone 7 + Tune2Air = No more skipping!
    Thought I'd throw this out there...I recently upgraded from an iPhone 6 to an iPhone 7 and I have not heard it skip or stutter yet. In fact, I was using it for about a week working flawlessly before I even realized that all of the skipping I used to hear was gone.
    The previous problem seemed to be that the Tune2Air bluetooth music connection would drop very briefly when the phone was communicating with the Audi MMI phone bluetooth connection. Not sure if the phone being faster, having a different bluetooth modem, or different firmware is responsible, but it is working great now. Not having a decent method to stream bluetooth audio was honestly my #1 complaint with my 2012 so this is a big deal for me!
    Here are links to threads talking about the problem...
    http://www.audizine.com/forum/showth...kipping-issue!
    http://www.audizine.com/forum/showth...layback-issues
    Established Member Two Rings punkalex1's Avatar
    Oct 26 2015
    Orange County CA
    ive had it connected to my samsung s6 for over a year and not once has it ever skipped, im assuming its only an iphone problem?
    Sep 24 2014
    Portland, OR
    Yeah, as far as I know, it seemed to be any variant of iphone 5, 6, etc.
    Veteran Member Three Rings Dannaye's Avatar
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Does audio sound just as good as aux though? That's why I've been skeptical to buying this. I also have an iPhone 7
    Instagram @Dannaye
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    It always sounded great when I had it. Then I just upgraded to 3G+ mmi.
    Established Member Two Rings antlaurence's Avatar
    Nov 05 2015
    Renton, Wa
    i have the 6 and when i updated to ios10, the problem seemed to go away.
    Jul 27 2016
    Louisiana
    Hmmm. Wondering how internals (BT?) of SE compare to 7. Does anyone have skipping with the 6S?
    Senior Member Two Rings Davidx1994's Avatar
    Feb 02 2015
    2019 Macan, 2015 Jetta TDI, 2009 A4 Avant
    Plainville, CT
    Quote Originally Posted by rainydaze View Post
    My 6S works perfectly. However, I never and any skipping problems with my 6 before I got the 6S.
    Established Member Two Rings vdubtucckn's Avatar
    Jan 26 2016
    Las Vegas, NV
    I've had my iPhone 7 now for almost a week and my biggest complaint is the Bluetooth connection (very skippy). I was told though that it was more of a problem with IOS 10 than the phone itself. IDK im not techy but I hope it gets fixed soon because its rather annoying.
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    What is the benefit of this rather then the stock BT audio streaming?
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Sep 24 2014
    Portland, OR
    Quote Originally Posted by antlaurence View Post
    Interesting. My wife still has the 6 so I might have to test to see if the ios10 update fixed the issue with for her. iphone 7 and ios10 happened same time so I suppose it could have been either that fixed my issue.
    No benefit. But this is pretty much the only solution for those of us stuck with just AMI if we want bluetooth streaming and to be able to see track info, use steering wheel controls, etc.
    Jul 27 2016
    Louisiana
    Quote Originally Posted by Blythiano View Post
    Please test and let us know!
    Veteran Member Four Rings a4_matt's Avatar
    Sep 19 2006
    Wanted: e30 calyso vert!
    Chicago
    I haven't had a single problem or issue w/ my iPhone6 and Tune2Air have
    Mar 05 2016
    Montana
    My iPhone 5c/iOS 9 had no problems, but I just upgraded to the iPhone 7/iOS 10. Now, whenever I turn on the stereo I have to disconnect and reconnect to the Tune2Air or else it displays "no playable tracks on this device." Any thoughts? Fixes?
    2009 A4 Premium Plus 2.0T quattro
    Mods: OEM gloss black exhaust tips; ECS gloss black RS 4 mesh grille; OEM titanium S5 peelers
    Active Member One Ring Turbo_mike's Avatar
    Feb 26 2014
    99.5 a4 1.8tmq
    ohio
    Quote Originally Posted by KNGBEAR View Post
    same here had no problems with iPhone 6+ with iOS 10 beta, Then when i got my 7+ I have to disconnect BT and reconnect to get it working again!!
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    I can report the same with my CarPro and my iPhone 7+. Works like a charm, but will be short lived until it gets swapped for a 3G+ MMI.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
