Results 1 to 18 of 18
    Oct 28 2014
    ON
    Fan FCM questions
    Both my fans stopped working all of a sudden. The highway was crawling very slowly and my temp went up. I polled over and neither of the fans was on. I tried with A/C on LO and the AC fan did not come on. AC was fine a few days ago.
    Does the FCM control both fans?
    If one fan is shorted would both fans stop working?
    From what I read the FCM has two power wires going in to it and two control wires.
    power
    brown - ground
    Red/Blue- constant 12v from fuse S42
    control
    red/white- acc 12v from fuse S4
    red/gray - Signal
    How does the ecu control the two fans independently with one signal wire??? Can someone direct me to the wiring schematics?
    Aug 26 2005
    The FCM has two sections, one for the left radiator fan, and the other for the AC condenser fan. They are independent from each other. The radiator cooling fan is controlled by the engine ECU. The AC condenser cooling fan is controlled by the HVAC controller in the dash panel. Both controllers send a PWM voltage to the FCM to start the fans and control fan speed. There are not two power supply wires to the radiator fan.
    Vorsprung durch Technik
    Oct 28 2014
    ON
    And what's the preferred replacement other than genuine $$$
    Aug 26 2005
    Quote Originally Posted by daught View Post
    A good used OEM genuine FCM. Check the fuses.
    Oct 28 2014
    ON
    So then the info is wrong and both thin wires are for PWM signal?
    If the two sections are independent I must not have power to the FCM then, right? How else would neither fan work.
    Aug 26 2005
    No way to control separate fans with one Fan speed PWM signal wire. Check the fuses.
    Senior Member Two Rings Preston_08's Avatar
    Apr 14 2014
    1998 Chevrolet C1500
    Richlands, VA
    power
    brown - ground
    control
    red/gray - Signal
    Both my fans burnt up not long ago. Didn't know it was the fans til I replaced everything I could besides those and didn't think to check them individually. Replaced my relay and the FCM before changing my fans. Tested my fans after I got new ones and they was both fried, wouldn't move an inch. I just never woulda thought both fans would die at the same exact time. Working like a champ now
    Oct 28 2014
    ON
    Anyone have the wiring schematics? It would make troubleshooting way easier.
    Good thing I am starting my timing belt today. It will be nice and open for testing fans.
    Sent from my DROID Turbo using Tapatalk
    Apr 14 2014
    Richlands, VA
    Might be able to google some...just used my Bentley manual for those. You check the huge blue fuse under the dash on the drivers side? Sometimes that blows out.
    Oct 28 2014
    ON
    I get power and ground on the big wires. One of the small wires is 12v and the other is PWM. So up to the FCM plug it's all good.
    When I turn on the car the PWM is around 0.3v, AC on 1.8 , car hot no AC 1.9v, car hot and AC 2.5v.
    Whole fan carrier is coming out tomorrow, I will test the FCM outputs and fans themselves.
    Apr 14 2014
    Richlands, VA
    If your fans are toast I recommend these aftermarket fan https://www.europaparts.com/dual-rad...8e0998455.html
    They had great reviews and are built better than the originals in my opinion, moves a ton of air.
    Oct 28 2014
    ON
    Will keep those is mind. The FCM power pin broke off from corrosion.
    May 07 2007
    Isn't there a way to test the fans by jumping wires directly to a 12v supply to rule out the fan motors being bad
    Sent from my Moto G Play using Tapatalk
    Apr 14 2014
    Richlands, VA
    Fan FCM questions
    Time for a new FCM that's sucks though
    And yes, just splice into the wires of the fans from a jump wire from the battery.
    Active Member One Ring monky's Avatar
    Jan 03 2013
    Nassau
    I have a similar issue if anyone can assist with this overheating issue. 2004 Audi A4 1.8T Quattro Avant. 165k miles.
    I was on the highway in stop & go traffic one day & the temp gauge started going up slowly. Then the coolant warning came up. I pulled off the nearest exit & was able to park at an Advance Auto. Popped the hood & there was coolant in the reservoir tank between min & max. I noticed that the fans did not spin. I let the car cool down a bit & drove home, the temp gauge went back down to the half way point & stayed there. I started googling the symptoms & apparently the FCM is known to go bad on these cars. I checked the fuse on the left side of the dash & the 5A fuse was ok. So I ordered a replacement FCM by Doorman from rockauto & my friend installed it for me. Fans still do not spin & the temp gauge will go up if I'm not moving but will start to go back down when I get going.
    Can it be the fans? Is there a relay that may have went bad? Where is the relay & how can I access it?
    I'm frustrated & about to go to the stealership. Any help or advice is appreciated.
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Does the little fan spin up when you turn the AC on? it should, no matter if the car is hot/cold.
    There's one relay in the ECU box, under the ECU. possibly another by your knees, inside the car.
    Fuses im not sure, i think also one of those locations.
    Jan 03 2013
    Nassau
    The fan does not spin with the AC on (temp set to LO & speed all the way up).
    Apr 14 2014
    Richlands, VA
    Should've checked your fans before ordering a FCM. There's a relay in the ECU box, and there is a big blue fuse under the knee bolster below the steering wheel. New Relay is $40 and idk about the big fuse. Scroll up and you can find the fans I put in my car since both of mine was burnt up. Test the fans directly by using your battery and jumper wire.
