Results 1 to 10 of 10
    Oct 05 2016
    Chicago
    Help a guy with his manual A4
    Hello everyone, Im fairly new to Audizine and the stick shift world. Ive been driving a 1999 A4 1.8t quattro manual. So far I feel pretty comfortable with stick shift except for one thing, how should I be driving it over Speed bumps? My neighborhood has streets with plenty of speed bumps, Ive tried two methods but not sure which is best. First method which I think is best is as I approach the speed bump I coast in neutral and use some brake, Once im over the bump I put it in second gear and just ease on to the clutch. Im not sure if this is okay since the car gets some shutter and the rpms drop to about 1000, but when I try instead to get in to first gear i feel some resistance as im shifting in to first. Any comments and help is appreciated.
    Senior Member Three Rings TheRedGlacier's Avatar
    Oct 31 2015
    1994 Firebird Trans Am GT 6MT
    New York
    Hey, nice job with getting the 'proper' tranny. Tip menbers might hate me for that. Anyway, I think I know exactly your situation personally. So that resistance.. If it is when you are letting out the clutch, it is the engine braking. Like it is slowly you down by raising the engine rpm. Also known as downshifting (which you already know). Anyway, I've always considered the 01A 5 speed manual to have a very awkward spot in the range.. Right at around 10-15 mph. If you shift into second, you lug the motor = no good. You shift to first, you throw yourself around = not comfy and makes you look bad to some. SO! If you are closer to 10mph, slowly press the gas when the clutch starts to grab, and that way you won't abruptly slow down with the engine braking. If you are closer to 15 - 20 ish, do the same, with second. Don't give it too much gas. It' may take some practice, but you just basically use the gas pedal to smooth out the clutch in awkward places like these. Hopefully that helps a little bit. I'll be around for awhile if that wasn't what you meant :p
    Edit: The shuttering that you described, likely linked with the whole car vibrating, is just lugging the motor. Basically your engine is trying to keep up with a tranny thats RPMs are very low, and it (the engine) isn't designed to run that low. So if you were to keep slowing down without going to first or neutral, or shift into third, or higher at that point, you would stall your engine, and have to fire it back up. Lugging isn't going to kill your engine, but try not to make a habit of it.. As the internal vibration at those low rpms is not going to do an engine any good.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Ride first gear over the bump?
    Sent from my Jailbroken iPhone 6s iOS9.3.3 using Tapashit
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 05 2016
    Chicago
    WOW im glad I joined this site thanks for the responses guys, Im already learning new things about my car, however what I meant by resistance is not when im letting the clutch out but I feel resistance in the shift knob, like im forcing it to go into 1st after the bump. Ive heard that if you feel resistance like that youre going in to the wrong gear, I wouldnt mind going over it from the start in first gear, but the way the streets are here it gets a but tedious having to shift up from 1st to second so im not going super slow, but then i have to hit another 2 or 3 bumps.
    Senior Member Three Rings dalazybastard's Avatar
    Apr 08 2016
    Orange County, CA
    My personal preference is to just do as you said. Coast over bump and depending on speed afterwards, shift into 1st(short/tall) or 2nd(long/flat) with a fair amount of gas.
    And you're right don't force it, but if you haven't already changed your transmission fluid; do it. It really cleaned up my shift into 1st and 2nd.
    Just a couple B5's, you know.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    I always come to a complete stop before the speed bump, put it into first then roll over it. Maybe because my cars are both slammed to the ground and I have to cut it completely sideways.
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    The resistance is caused by your syncros. Either worn or the speed differential between engine and transmission is to great.
    I've personally never thought about how I shift on a speed bump, just slow, because I am slightly lower. That and my lowest point is the muffler right behind the front wheels.
    Jun 25 2015
    California Hawthorne
    Just make shure you hit the bump at a steep angle or else you'll pop the oil pan "slammed life"
    Orange County, CA
    Quote Originally Posted by b6Hate4 View Post
    I do it the same way. People must love me when I roll over speedbumps... Sometimes people blast around me in parking lots, etc since I don't run over speedbumps at full speed. Not my problem, no rush in parkinglots or roads.
    B5 Parts For Sale
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    You may have to double clutch too get it back into first of second, but first is a pita, can't get mine back in of I'm going over 10 mph
    Sent from my Nexus 5X using Tapatalk
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
