Thread: need tire help
    Active Member Two Rings joeylovesaudi's Avatar
    Jul 08 2014
    milwaukee
    need tire help
    Can i change my stock 17" wheels to a set of 18" hartmann euromesh 4-ga4 with dunlop winter sports on my 2011 a4 prem plus
    thanks so much
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    No
    Sent from my Nexus 5X using Tapatalk
    Jul 08 2014
    milwaukee
    Quote Originally Posted by BrewDude View Post
    No
    why, it has the same 112-5 size?
    Dec 01 2011
    yes you can, as long as it's 5x112, 66.6 centerbore size. and you have to get the right tire size too, for 18s the stock size is 245/40/18.
    IG @theshawon
    Jun 30 2009
    Washington DC
    Also, it may not matter since Hartmann makes wheels for the A4. Just make sure you use the correct bolt for your aftermarket wheels. In your case it would be a ball seat bolt which is what the OE wheel uses.
