Results 1 to 8 of 8
    Aug 28 2015
    1991 nissan 300zx twin turbo 2005.5 audi s4
    San Antonio Tx
    Exclamation Tire Sizes and Coils
    Hello guys I recently installed some Solo werk I'm running 19x8.5 35 offset and 235/35/19 I'm wanting to change to 245/35. Is anyone running anything similar and experience any rubbing, reason I'm asking is because I've been experiencing sidewall damage with this size tire. Looking to get tires by this weekend. 2006 Audi s4
    Thanks in Advance
    Edgardo
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Depends on your ride height.
    Aug 28 2015
    San Antonio Tx
    right now its sitting pretty low fender is over rim not much clearance not looking to stay that low for much though
    Jun 07 2013
    West
    I've used 235/35R19 for 10 years. That is the most exact match for overall diameter (almost perfect). You need better tires! I suggest Michelin Pilot Super Sport. I have never had one issue in all these years. Make sure you have the right air pressure for this size also!
    Aug 28 2015
    San Antonio Tx
    Thanks guys
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    You also want a 95 load rating on the tires. These are heavy cars.
    Old Geezer, formerly known as Stud Muffin
    Aug 28 2015
    San Antonio Tx
    Thats the reason I want to go up a size
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Quote Originally Posted by Concavitor View Post
    +1 for this. I ran 235/35 x19 for a long while. No issues
    If you're going one size wider and not wanting to raise the car, you're gonna hate your life. You might even get more sidewall damage because of rubbage issues. It does depend a bit on your offset but if you're keeping the same wheels, then maybe not the best idea.
    Edit: I guess I misread and you actually don't want to stay as low as you are. If you raise it up, you're probably fine. The only issue is I doubt you'll find 245x35 tires with the right load rating. Going from 91 to 93 will still be better though
    Sent from my potato
