Results 1 to 4 of 4
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    spherical sway bar end links klunk
    im getting a klunk in front and the rear now that i have solid sway bar end links. is this normal? i cant see any obvious loose parts or improper installation. this is frustrating, i thought i would be way solid but every time i hear a klunk it gets under my skin.
    ok so we took care of the control arm klunk, we took care of the coilover spring pre-tension klunk (assuming there was one) and the only thing left imho would be the vibration transmission via solid links.
    any opinions?
    Established Member Two Rings Groucho's Avatar
    Sep 06 2014
    2001 Allroad 6MT swapped, 1999 Toyota LC, 2001 Allroad TIP
    Colorado
    Just throwing this out there-it may not have any bearing whatsoever-- but have you tighten down the bolts associated with the steering underneath the battery box? When I was trying to troubleshoot my front end clunks, that was one thing I remembered being suggested that I would've never thought. And it was loose by about a half a turn.
    Jun 04 2013
    SE MI
    not yet but thats something ill check, thank you!
    Jun 04 2013
    SE MI
    has anyone else experienced this
