Results 1 to 10 of 10
Thread: First A4
    Active Member Two Rings two80one's Avatar
    Sep 22 2016
    Ontario
    First A4
    Well, after looking high and low all across Ontario I finally found an A4. Just down the road from my house.
    Elderly lady owned this 2010 A4 Avant and traded it in for a brand new 300S (I wouldnt consider that a step up by any means). I ended up getting the car for 15k out the door with 122k on it.
    I don't have any plans for the car except to maintain it, tint the windows, and put a nice set of wheels and tires on it.
    The local shop told me these A4s had a timing chain. What is the service life of the timing chains?
    Thanks.
    Sent from my SM-G730W8 using Tapatalk
    2010 A4 Avant Quattro 2.0T Sport
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    Congrats! Nice avant!
    Timing is an issue on the b8. Supposedly "lifetime" but evidence in the forum would suggest otherwise. Search in the b8 section for timing chain tensioner and you will see what I mean. Issues tend to arise around 85k miles, but there is some cases much earlier and others much later/never.
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    No expert here by any means....chain is supposed to be 'lifetime' but that really depends on the timing chain tensioner - which unfortunately has been failing more often it seems lately. Might be one of the first things you do considering the mileage.
    In any case welcome to the club! I would also considering swapping out those halogens - BiXenons really transform the car IMO.
    Cheers,
    Ry-man
    Sep 22 2016
    Ontario
    Quote Originally Posted by CONative View Post
    TC service noted. I'll bring it in and have it serviced ASAP.
    I've been looking into getting a pair of BiXenon units but my dealer around here was looking for $750/ea. Lol
    Feb 02 2016
    nevermind my last post, i didnt realize its canadian dollar. I agree with the above post, the timing chain might need to be replace.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Services to do immediately if there are no records of it being done:
    -Call dealer with VIN #, get service history.
    -Timing chain + Tensioner/ guides...just get it all done at once.
    -Carbon clean! Do not overlook this.
    -Double check water pump for leaks.
    -Flush fluids of Trans, Diffs, Brakes, PS fluid ect...
    Doing this ASAP will get this car rolling happy for many miles to come!
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    ^^^this, but make sure the service history shows that the pistons and rings were replaced relating to the oil consumption issues on '09s, '10s and 11s.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    May 10 2015
    Pittsburgh PA
    Search ebay for a used set of Xenon headlights as well as the classifieds here, some people sell theirs after upgrading to E-codes.
    As mentioned previously by most everyone else. maintenance, maintenance, maintenance. B6hate4 covered most of the bases there
    As far as oil consumption goes, I wouldn't be too concerned about whether or not you car had any warranty work done as a result of that. The class action law-suit ended a couple months ago and even if it was still in effect, they only warrantied oil consumption until 75k miles. As this point it is what it is, hopefully your car is fine. Enjoy your Avant!
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by 19birel View Post
    Lambda13 has a set of Ecodes he is trying to sell oddly enough...
    Wanted to trade me for stocks. Maybe he would let them go cheap.
    2016 S3
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by b6Hate4 View Post
    Fuck, I would trade my stocks. They're even out of the car.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
