Originally Posted by
bhvrdr
I've been curious about this. Its commonly stated that "boost is a measure of restriction" and doing things like adding headers or cams will reduce boost.
I added longtubes to my other car and I actually didnt see any change in boost at all. It got me thinking...uh oh right.
For all naturally aspirated cars the manifold pressure is always 14.7psi or just over 1 bar at WOT. Why does this pressure not change no matter what cams you use or even if you ran no exhaust at all? Its because thats the maximum pressure available to put into the engine (natural pressure or ambient pressure). Isnt boost pressure actually how much the turbo or supercharger is compressing the air over ambient? If so, is this really impacted drastically by cams or exhaust? I've been trying to wrap my head around it better.
Thanks,
Mike
Hey Mike, yes you are correct boost is a measure of restriction on any air pump (engine) and the more efficient you make it from the cylinder heads to the exhaust tips, the less boost you will make at the same or greater power level while seeing lower iats. Imo the reason you didn't see a drop in boost pressure from adding headers on your other car is because the exhaust wasn't a restriction at that boost level. Same thing with cat back exhausts on the 3.0T with just a stage1 or 2, stock system isn't restrictive so there's no change until you remove the cats, which are the restriction. Also the size of the air pump (engine) directly effects the gains when improving airflow...the larger the pump, the better the gains.
When you change cams the vacuum of the engine will be different and depending on lift/duration you should see a drop in boost pressure as you are improving the air pumps efficiency. Boost is always just a measure of restriction...if you're spinning the blower at 24k rpms and making 20psi, but then add headers with full catless exhaust, now you might only be at 18psi at 24k rpms, but it's making more power, more efficiently, with less restriction. Grab your wife's blow drier and turn it on high. Now cover the air outlet with a bag that has one little hole in it, listen to the sound of the drier and feel the flow blowing out of it...then remove the bag, listen and feel how much more blows out of it. I wouldn't say cams or exhaust drastically change efficiency, but they help move more air.
Hope that helps brotha!
Will
