Results 1 to 12 of 12
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    what 19" wheels fit over s6 brakes
    looking for a set of wheels to run 19" winter tires on and i dont want to order a set of wheels that wont clear the rather large s6 brake calipers.
    anyone buy anything from alzor or hartmann?
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Established Member Two Rings Beezer14's Avatar
    May 14 2015
    Chicago
    I have the same need for my S7.
    Mar 15 2009
    Arlington, VA
    I use these, factory 19" from A6 Sportline (I think). They fit S7 without spacers, but I use 15mm spacers to get them to stock track width. I think for S6 they would probably look fine (and fit fine) without. I think they are the same size and offset as stock S6 19" wheels, but they might be half an inch narrower.
    http://pictures.dealer.com/b/bellaud...fcee87b30x.jpg
    Current: '13 S7
    Past: '01 S4 Avant, '89 200TQ Avant, '98 A4 2.8Q Avant, '04 S4 Avant, '01 TT180Q
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Hartmann has a few 19" choices for the C7 S6.
    The Hartmann HRS6-091-MA:M
    The Hartmann HRS7-163-MA:M (requires 3mm spacers)
    The Hartmann HTT-256-GS (requires spoke balancing)
    The Hartmann HTT-256-MA:M (requires spoke balancing)
    https://www.achtuning.com/audi/s-ser...-2013-present/
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Factory 2013 A6 3.0t 19" sport package wheels fit.
    Oct 16 2012
    pa
    Quote Originally Posted by Brooklyn View Post
    do you have a picture of what you're talking about?
    May 08 2004
    NoVA
    These are the factory 19" sports package wheels from the 2013 A6 3.0t. I traded them to a guy with a C7 S6 and he confirmed they fit perfectly.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Mar 15 2009
    Arlington, VA
    In case it helps, I am reasonably certain that any wheel that fits the S6 will technically fit the S7, and vice-versa. I'm pretty sure the brake and suspension geometry is the same between the two. The S7 is a wider car, and has a wider track, and so the factory wheels are (like-for-like) a half inch wider and have 8mm less offset, so sit 14.4mm further out. I think that makes up for the entirety of the difference in width of the body/track, but it means the A/S6 wheels look goofy on the A/S7. That is why I run the 15mm spacers when using the A6 19" winter wheels. Vanity.
    Current: '13 S7
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Base s6 wheels are 19's right? Black optics come with 20's
    Anyway, find out the specs on the base wheels and there you go.
    My 19 inch renn 51 from my s4 fits. 19x9.5 et 42
    Edit: here is the stock 19 specs 8.5Jx19 ET45
    Tire size : 255/40ZR19 99Y To keep the abs sensors from going into a fritz and speedo regulated
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Oct 16 2012
    pa
    Quote Originally Posted by DGVR6 View Post
    The problem is that the factory wheels are very close to the caliper at the spokes and the barrel so I'd imagine it will be an issue with most other 19's
    Aug 03 2014
    Queens
    I understand now,
    Maybe renn51 might be a good choice, I'll be using for the track/winter
    Previous
    Mar 26 2010
    US
    Hartmanns are a great choice. I have the 19"x8.5" et=38, Hartmann rotors on my 2016 S6, they fit well but it's tight. Americas tire had no problem with spoke balancing.
    2019 RS5 Sportback
