Not in LA but same car same problem...
Went to a meet with a local buddy who had the AWE Touring Exhaust on his car.
Just driving around with him made it very clear that the B8 NEEDS an exhaust.
Didn't want to drop the ~$2k on the setup so I decided to go cheap and change it up later if needed
My setup:
Originally Posted by
whiped
Total cost installed came out to ~$550
Didn't get a chance to take any good pictures while it was on the lift
Mine is a little louder, his is a little deeper at idle currently although that may change as I break mine in. At WOT they sound fairly similar.
I drone a bit around 2,400-3k RPMs once the exhaust heats up. I put sound dampening mats under the spare tire in the trunk which helped a bit.
Haven't decided if I want to put it back under the knife yet, the drone is only occasionally bad at partial throttle situations.
As of right now I am very happy with my exhaust especially for the price point.
If you wanted you could do just the MF 11385 in place of the babys, straight pipe through the center res and leave everything else in place.
Total cost should be <$300 and will really bring the car to life.
If you want more after that then buy the AWE system.
