Results 1 to 10 of 10
    Established Member Two Rings bbova1's Avatar
    Jul 13 2015
    Saratoga, ny
    Rear Sway Bar for A4
    Up for sale is a 22mm rear sway bar from a b8 A4. The stock size is 16mm. Note this will not fit a B8.5 A4. The part number is 8K0511305AB. Looking for $100 shipped
    As you can see the diameter is drastically bigger.
    https://www.ecstuning.com/b-genuine-...r/8k0511305ab/
    Veteran Member Three Rings Dnovakovic04's Avatar
    Feb 02 2016
    Thousand Oaks, CA
    Pm sent
    2016 Glacier White SQ5 Prestige
    - AWE Touring Exhaust - IE Stage 2 Single Pulley - Roc Euro Intake - 034 Trans Mount - Alu Kreuz -
    Jul 13 2015
    Saratoga, ny
    Bump obo
    Jul 13 2015
    Saratoga, ny
    Bump to 80 shipped
    Jul 13 2015
    Saratoga, ny
    And this is for a avant only not a standard A4 as the fitment is different hence the reason I am reposting to sell.
    Jul 13 2015
    Saratoga, ny
    Bump for any avant owners make me an offer
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    Did you run this? Any difference noticed? How would this compare to 034/h&r/etc? Are you selling just the bar only or end links as well?
    Jul 13 2015
    Saratoga, ny
    I did not as it only fits avants...OE is 16mm and this is 22mm. H&R is 24mm. I think it would definitely make a diff as you can see from the pic comparison
    Jul 13 2015
    Saratoga, ny
    Accidental order from a fellow avant owner we both thought it would work
    Jul 13 2015
    Saratoga, ny
    Sold
