Results 1 to 40 of 48
    Established Member Two Rings Garro's Avatar
    Sep 18 2016
    Round Lake IL
    Angry Unitronic Stage II+
    I have a 2012 S4 that I got flashed to Unitronic Stage 2+ and the Car is impressive. Now I bought a Uni-connect cable and that is where my experience is going downhill. First of all the Dealer didn't assign the cable to me properly and secondly during the software installation registration now the cable will not work until I get Unitronic technical service to access my laptop and set it up. I am an air traffic controller and its impossible to do this at work so i took a Day off which is in effect almost an impossible task but I pulled it off. The tech told me to call at 8:00 AM which I did only to be told that I called in late because I am on Central Time, now I am hold for when the tech has a chance to call me back which could be basically anytime because he could not give me even an approximate time. Problem is that I also have a 12:00 o'clock appointment at the dealer and I know that my car will be getting the ECU update. I bought the cable just for this reason as I am 30 miles from the closest dealer, I am now regretting my purchase and actually thinking of getting the car re-lashed with APR as my Jetta TDI is. There goes my plan to give Unitronic a chance and to be truthful the flash is great but they are under staffed and it seems only one IT specialist is in house there. So there is my experience so far and it just sucks!!!!
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    I'm sure (hopefully) it will all work out. I wouldn't think you'd need Unitronic to access your stuff to set anything up. I would expect a cable to be registered and the program to do the rest. If it wasn't registered properly, they should be able to do that fairly simply.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Senior Member Two Rings withENEMYin's Avatar
    Jul 24 2014
    2017 Q7 3.0t, 2008 Q7 4.2L
    Chicago, North Burbs
    Yikes, if you can get your money back both APR and GIAC are on the verge of pushing out "Stage 3"
    Good Luck.
    2014 RS7: Milltek Turbo back, RocEuro Intakes, Ported TB
    Sep 18 2016
    Round Lake IL
    Quote Originally Posted by cjw View Post
    I was told by the Tech at unitronic that he needs remote access to fix it. Which is fine but my beef is that it seems only one person does it as I spoke with the same person
    every time and unlike other companies they set appointments in their time zone and don't tell the customer that. I am just impatient maybe just impatient but at this point
    but if I don't get it done today I will be returning the cable and taking up APR on that offer that they are currently promoting.
    Sep 18 2016
    Round Lake IL
    Quote Originally Posted by withENEMYin View Post
    Good Luck.
    How do you like the GIAC tune?
    Dec 07 2014
    Mn
    Sounds like your problem is with your dealer. Once it's set up properly it's great.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Sep 18 2016
    Round Lake IL
    Quote Originally Posted by brianc21 View Post
    I am dealing directly with Unitronic the dealer did correctly assign the cable now it is out of the dealers hands my dealer cannot do a thing with my laptop.
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Totally different experience on my side: My dealer had also tagged the cable to the wrong user (themselves actually). So I called Uni and they changed the registration on their side, over the phone, 30sec later I was in.
    Murdered B8.5 S4
    Build Thread
    Sep 18 2016
    Round Lake IL
    Post
    Quote Originally Posted by silverf0x View Post
    I understand what you are saying but my problem is during the software setup the cable gave back an error code that the Unitronic Tech told me requires remote access to my PC and its done by appointment only. I maybe just too skeptical but all these companies are so willing to take your money but then fall short in support when needed, now I am not slamming unitronic alone because from reading the forum it happens with most of them. Remember these are not exactly cheap products and they are used in a very expensive Automobile, all we need is service and then this conversation would be mute.
    Sep 18 2016
    Round Lake IL
    Now I am heading to the dealer hope they won't TD1 my car as with that the value in a resale is shot. Thanks for the really bad service Unitronic!!!!
    Jun 21 2004
    mpls, mn
    Quote Originally Posted by Garro View Post
    Why not delay your dealer trip until the issue is resolved?
    Jul 24 2014
    Ive been running it for almost 9 months, dual pulley and not one issue thus far. I think we met last week with your nephew, didn't you go Unitronic because you still had warranty left?
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    whats in the stage 3 aside from dual pully?
    Jul 24 2014
    Quote Originally Posted by sirsycott View Post
    Im only running stg 2, but I believe there are other members helping GIAC testing files for stg 3. It looks like it would be an updated tune + a HPFP.
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Dude if you go to the dealer for the ECU update with a Uni tune you are 100% get TD1ed!!!!! DONT GO!
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Sorry to hear that and I hope everything will work out fine eventually.
    It seems like everything came together while you had a very tough schedule
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Apr 05 2016
    Portland, OR
    Mostly upgraded cooling.
    The HPFP is only needed if you are blending fuel.
    As of right now I am planning on going with a stage 2 meth kit instead of an HPFP as E85 is not easily available in my area.
    +1 on not going to the dealer. Say something came up.
    Geoff
    Sep 18 2016
    Round Lake IL
    Yes we met! Will you be at the show on Sunday? At the dealer and they will not flash my ECU so everything is cool.
    Sep 18 2016
    Round Lake IL
    Check out the Meijr locations they have E85 one is a mile from my house but I didn't mix any fuel yet with the Uni Tune interested to know if anyone did. Your car is awesome, we talked about it when we left the show.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    +1
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Sep 10 2012
    DFW
    I have had this tune (Unitronic 2+) now for almost two years and love it. I have tried E85 for a month and it was great but as you'll find out it's hard to mix and after the 4th tank I had to much EE and it threw a code. I filled up with 93 octane and it cleared. It's like sex the first time is the most exciting lol. Seriously, the first time I added 4 gal and filled the rest with 93 and it ran the best. I think if your going to do it on a regular basses 2.5 E to 10 gal 93 and you should be fine.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Dec 07 2014
    Mn
    The UniConnect has worked great for me. I had one cable malfunction which was quickly replaced by John. Since then have had zero issues. Flashed back several times for dealer visits or road trips where I know I won't be able to find the 93 octane. I'd have zero interest in being tuned if I was forced to have to go in and pay a dealer for ever flash back. Be patient and get your issue resolved, once it's working you won't regret it.
    Sep 18 2016
    Round Lake IL
    Yes I love the product don't get me wrong but maybe this guy is just rubbing me wrong. He said he recall Mr back Today so we'll see if he does, just feel that I am being taken for granted. I am still in my 15 day return period so we'll see what he does.
    Jul 24 2014
    Hit up s4matty here for a 194mm crank pulley. Then take it over to Dub Werks for install and GIAC stg II or if you go APR route take your ride to Dynarev. Both are great Tunes and Shops to get work done.
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    I have a 186mm pulley i got from S4matty i will be selling shortly, got a good deal on a dampened 179mm.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Sep 18 2016
    Round Lake IL
    I already have the Unitronic Pulley installed I wonder if anyone knows the specs?
    Jul 24 2014
    Check out the chart on first page.
    http://www.audizine.com/forum/showth...lopment-thread
    Sep 18 2016
    Round Lake IL
    Thanks and here is what happened. John from Unitronic got on after I finally got fed up to wait anymore and found out that the wrong cable was sold to me by the dealer. The dealer called and told me that a cable was shipped overnight and they will call me when it arrives. I am out a day but will survive . Will fill you in about the rest of the process.
    Sep 18 2016
    Round Lake IL
    Wow!!! Unitronic customer service! Was told by the dealer that the correct cable was shipped standard ground s o it will arrive on Tuesday. Just blogging about the attention you will get after spending your money. Will let you all know what happens after I try to setup the new cable after really being doubted by Uni service help that I did something wrong when they have old hardware still being sold at their current dealerships.
    Sep 10 2012
    DFW
    I blame the local shop that sold it to you. The Unitronic local shop here was the best.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Dec 07 2014
    Mn
    Quote Originally Posted by TexasDfwS4 View Post
    This is exactly what I said from the start of this thread but he chose to ignore it.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    sounds like a pretty simple issue to fix, my dealer had done the same and had it fixed within minutes
    Love Uniconnect compared to some of the other flash at home systems :)
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Sep 18 2016
    Round Lake IL
    I will see when the part gets here on Tuesday.
    Sep 18 2016
    Round Lake IL
    I will see when the part gets here on Tuesday. The Tune is perfect not bashing the product but the customer service can be improved. Are any of you running another DSG Tune along with the unitronic ECU Tune?
    Stage 3 Forum Advertiser Four Rings ModdedEuros's Avatar
    Aug 23 2014
    Philadelphia, PA
    Sorry you are having issues with the cable. We sell a ton of these every month and rarely have any issues. A lot of the issues generally can be avoided (wrong info entered like VIN, emails etc) or people buy cables without tunes which require little extra work on both sides to get the proper tune files assigned. But we have nothing but good things to say about Unitronic and the tunes. Even customer service.
    We have common FAQ and questions in a video we did. If you want to check them out we cover those issues here
    Modded Euros
    Your Source for Audi & VW Performance Parts
    www.ModdedEuros.com
    Veteran Member Four Rings GrkA4's Avatar
    Jan 14 2005
    B8 S4, MkV R32, B6 A4 (gone)
    Newtown, PA
    Same here. The Philly area shops are top notch. I had zero problems.
    B8 S4 Sprint Blue - UNITRONIC Stage 2+ & S-Tronic Flash, Roc-Euro Intake, Magnaflow Exhaust w/ non-resonated downpipes, Eurocode Sway Bars & AK, 034 Trans Mount
    MkV DBM R32 - VF Engineering Intake, Magnaflow Exhaust, HPA Dogbone Mount, Neuspeed RSB and End Links, H&R Springs, RNS-510
    CB Tuning
    Unitronic
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    I'm very sorry about the issues that you've encountered, but glad that it's in the midst of being resolved. If you require additional support, please do not hesitate to let us know.
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Sep 18 2016
    Round Lake IL
    Got it resolved and as I said I would give you all an update. The reason was not Unitronics fault but the dealer gave me the wrong cable
    John thanks for all your help discovering the problem, I am sorry if I rubbed you the wrong way the other Day but as you know how Men
    are with their Toys please forgive me. I will patiently wait for the DSG Tune because the ECU Tune make my car perform like night and
    Day in comparison to the stock tune. I am now glad I have the ability to return to the stock tune without driving 30 miles to my closest dealer.
    Sep 10 2012
    DFW
    I commend you sir, and hope you enjoy the tune I know I am.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Sep 18 2016
    Round Lake IL
    I am
    enjoying it for sure and just hoping that the DSG Tune is released for Christmas. I am getting used to the software and may try
    the 89 octane tune just for the hell of it. I will go back to stock so they can do the recall update then reload the tune. I
    even wonder if that makes sense or if the tune will just rewrite the whole ECU Map making the update null and void.
