Results 1 to 26 of 26
    Aug 19 2016
    san jose / ca
    2013 S6 oil consumption.
    Hello all.
    I bought my 2013 S6 a few months back and have put in 3 quarts of oil already without hitting 5K miles. I didn't do the oil change but trust that the dealer did the right steps and put in the correct amount (could be wrong here). I believe they used Mobil 1 full synthetic, but can't confirm that either.
    3 quarts in between oil changes seems very excessive. Not seeing oil leaks or smelling burning oil. All other indicators are normal according to onboard systems. I drive fairly conservative and often stop and go traffic. Is this normal or should I be worried?
    Any advice would be appreciated.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Yes this is abnormal.
    What made you decide to add oil? Low MMI reading? Warning saying oil level is too low? or something else?
    I would go back to the dealership.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Aug 19 2016
    san jose / ca
    Thanks for the note. Yes, the oil indicator prompts me to add more oil every few weeks.
    Junior Member Two Rings
    Aug 08 2016
    ohio
    Has to be a leak. Take off the belly pan and I bet you will find some oil. My guess is someone put to much oil in it and blew the main seal.
    2013 S6 estoril blue
    Previous: 07 A8L
    01 allroad
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    3 quarts in 5k miles is excessive. However it is not out of the ordinary for these cars to need a quart after 5-7k miles. There is a little blurb in the owners manual about oil consumption.
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Jun 03 2013
    Milwaukee WI
    Fellow 2013 S6 owner here - this is definitely abnormal - I have not needed to add oil before changes.
    Aug 19 2016
    san jose / ca
    Thanks all. I am getting a pre-track check tomorrow so I will have them take a look at belly pan.
    One thing that started recently is a rough idle when stopped at traffic lights. Shift to N and it goes away. I saw a thread where folks had similar issues. http://www.audizine.com/forum/showth...traffic-lights
    Not sure if they are related.
    Mar 26 2010
    US
    Could be a vacuum leak causing rough idle.
    Oil issue may be related to PCV?
    2019 RS5 Sportback
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Definitely not right. Could be the PCV valve, like wwhan said, as it will cause rough idle and excessive oil consumption. Some also notice a whistle at idle, when the PCV valve is faulty.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Aug 19 2016
    san jose / ca
    So, PCV valve is just fine and no oil leaks at all. They found that 3 of the 8 cylinders are miss firing! The shop thinks they are bad spark plugs.
    It does seem odd to have bad plugs with <45K miles. Sucks, was supposed to track it for the first time tomorrow.
    Mar 26 2010
    US
    Quote Originally Posted by smaroju View Post
    Plugs can be fouled with oil, from bad rings & cylinder walls or valve guides.
    Maybe consider running a leakdown test on the cylinders or a compression test.
    2019 RS5 Sportback
    Aug 27 2015
    New Zealand
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Plugs get changed at 35k I believe. If they were changed, fouling after just 10k miles would be mighty peculiar.
    Aug 19 2016
    san jose / ca
    Fingers crossed it is only plugs! This would be a nightmare.
    Aug 27 2015
    New Zealand
    I hope so too, but plugs don't explain the oil usage.
    Aug 19 2016
    san jose / ca
    So, i got the spark plugs changed out. No fault codes are showing from the on-board system. The idling seems to have gotten better but still a little rough. Going to run it for a few days and see how the oil consumption and idling go.
    Fingers crossed!
    A few folks mentioned that Audi recommend swap at 35K. I can see why:
    https://www.amazon.com/clouddrive/sh...hare_link_copy
    2013 Audi S6||Brilliant Black||B&O sound||Factory 20" Wheels (for now)||GIAC ECU Flash||AWE Touring Exhaust||RocEuro Intake||Custom Tint||RS6 Honeycomb Grille||Coming soon....Front/Rear Sway bars|VagCOM Lowered||
    Aug 06 2014
    NJ->CO
    Fingers crossed!
    It would be good if someone could post pics of their 35k plug change on a car with no issues for comparison.
    Yours may be indicating symptoms of other problems and not just normal 35k or even 45k mile wear.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    Quote Originally Posted by gk1 View Post
    Looks like detonation...ping
    2016 S6 Mythos Black Metallic, B&O Sound, Sport Package, Driver Assistance, Comfort Seating, Black Optics, Audi Exclusive Interior.
    My wife said its golf or her, gosh I'll miss her!!
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by goliath1 View Post
    If you are referring to the odd look of the side electrode that is normal for this type of plug, but the ashy buildup is what looks odd to me. However if he is truly burning oil that might be what we are seeing in his pic.
    Here is a pic of a brand new plug to see the odd looking side electrode.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Aug 19 2016
    san jose / ca
    The never ending saga continues....
    A week ago the EPC light and check engine light go off and I have major power/acceleration loss in the car. Worried about more damage i get it towed to my shop. They mentioned that the ODB was still reading mis-firing even after the spark plugs are swapped. I change all the ignition coils as recommended. During the test drive, they notice the car was still "sputtering. Replacing the diverter valve in the car now. They did say that there was oil leaking from the diverter valve, which may be the root cause for the oil consumption.
    OMG...this is getting expensive!
    Established Member Two Rings turbello18's Avatar
    Nov 12 2010
    08 Q7 Sline
    Manchester
    No warranty?
    '13 S6
    Aug 19 2016
    san jose / ca
    I have a tune and other mods that void the warranty.
    At least my local dealership is claiming that the warranty is voided.
    Car seems to be running well but there is still a strange knock at 50% throttle.
    My shop wants to flash back to stock and test. I think that may be the best option.
    I can always flash GIAC tune after the logging.
    Senior Member Three Rings Cris_OO7's Avatar
    Jul 08 2010
    Woodhaven/NY
    any update did u find out what it was?
    Jul 27 2013
    indianapolis/indiana
    elephant in the room why didn't you flash back to stock prior???
    2003 RS6 Apr stage 1 and tiptronic, Apr divertors, Clear bra, Yellow konis SOLD
    2014 S7 Audi exclusive edition 1, Havana black metallic exterior, Havana brown interior, APR stage 1 ECU/TCU, Total Loss Wreck
    Jan 09 2013
    UK
    They'd know if it had been mapped anyway even if you flashed back to stock. With engine issues like that they always send the data back to Germany.
    Nov 23 2017
    New Jersey
    Car is more then likely
