Results 1 to 20 of 20
    Oct 04 2016
    Jeep Grandcherokee 2008, Lancer 2007, Ducati M750
    Amman, Jordan
    audi A4 2005 2.0 problem
    Hi guys,
    i need help please with my audi A4 2004, recently i had that PNDR flashing problem from transmission and sometimes i couldnt get car to reveres, so i took the car to the dealership and after checking it they said that i have to change the TCM, so i changed it and i paid a freaken 4000$ !!
    the problem is when i got my car back, it feels very heavy, like motor braking all time,, as soon as i remove my foot from pedal car decelerate and lose its speed and like if i go downhill car would raise rpm and it wont upshift.
    i took it to dealership many times ,, and every time i leave it and they say that there is nothing wrong with car. however the problem is still there.
    im very frustrated especially after paying that amount of money,, any help would be great!
    Nov 03 2011
    All Over!
    It sounds like the TCM has not been synced to the car. A new TCM has to be put into "learning mode", otherwise it will have erratic shifts, shift up too late, or downshift too early.
    - - - Updated - - -
    I take it, this is a FWD car, with CVT, right?
    1986 Type 85 Audi 90 quattro
    Oct 04 2016
    Amman, Jordan
    So what should i do? Everytime i go to dealership they test it add say everything is fine
    Oct 04 2016
    Amman, Jordan
    And yes it is , FWD CVT
    Oct 04 2016
    Amman, Jordan
    To add , even when i change to R now , the gear doesn't engage directly, like if i was on inclined road and car front is facing downhill the car would move downhill for like 30cm before the R gear engage.
    Nov 03 2011
    All Over!
    Quote Originally Posted by ahmadmuqbel View Post
    It sounds almost like the engagement points are wrong.
    What does the car idle at?
    Oct 04 2016
    Amman, Jordan
    About 1000rpm ,, but let me check,not sure
    Jun 26 2015
    Tampa, FL
    I don't know if there's a difference in the transmission, but I know there is in the engines. You have a B7 if you have a 2.0T.
    Oct 04 2016
    Amman, Jordan
    No its not 2.0T ,, its 2.0 and dealership said that they brought the exact TCM for it regarding its VIN ,, "thats what they claim at least",, and Nollywood i will check the rpm when my old man comes home, its his car, should be here after few mins
    Oct 04 2016
    Amman, Jordan
    It sounds almost like the engagement points are wrong. ?
    Btw it was perfectly fine beforw changing TCM , just sometimes R wouldn't engage, but transmission engagement points was perfect, the car is for my father and it has only 50000 km and always maintained
    Jun 26 2015
    Tampa, FL
    If it's a 2.0, it has a turbo if it's an Audi. Unless you meant 3.0?
    Oct 04 2016
    Amman, Jordan
    Quote Originally Posted by rocket1420 View Post
    No my friend,, ours is 2004 A4 2.0 no Turbo
    - - - Updated - - -
    I just checked mate ,, it idle exactly at 800rpm
    Nov 03 2011
    All Over!
    The B6 in Europe and Australia, was available with two 2.0 litre motors.
    1984cc I4 20V, 130hp.
    1984cc I4 16V FSI, 150hp.
    Nov 03 2011
    All Over!
    - - - Updated - - -
    I think you'll need to pull codes, and post the results here. It's possible the dealership's giving you a snow job.
    Oct 04 2016
    Amman, Jordan
    Exactly and ours is the 20V ofc since auto
    Oct 04 2016
    Amman, Jordan
    So i should go to some shop with Vagcom ? To pull codes ,, because whenever i go to dealership they say no faults ,, and charge me, so stupid
    Oct 04 2016
    Amman, Jordan
    There is no check engine light or any warnings on dash ,, does it worth to disconnect the battery for while ?
    Nov 03 2011
    All Over!
    Yes, you'll need a shop with VCDS, or at least the equivalent, that can scan the TCU. You may not have a check engine light, yet still have a code stored in your TCU.
    The indicator that shows PRNDS or similar on your dash, what's it like? Is it any different from normal? Is it showing the selected gear, or is it all lit up? I can't remember what a CVT indicator is like.
    Oct 04 2016
    Amman, Jordan
    The indicator on dash is fine,, it have a square to indicate the selected gear, so its normal
    Oct 04 2016
    Amman, Jordan
    Its really annoying issue,, i searched the net for long ,, theres nothing about my issue,, i will do as you say and go to some shop to scan TCM
