Results 1 to 19 of 19
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Wink 2007 A4 Avant S-Line with K04 and all upgrades
    2 owner car, I purchased it in 2010 after looking for over 6 months for a Dolphin Grey colored one that was fully loaded.
    The car is originally a California vehicle, and is now in Vancouver, BC Canada (where I live). All prices below are in Canadian dollars for the same reason, but you guys know what the parts are worth anyways.
    It is the 2.0T FSI 4 cylinder model, with Quattro, and Tiptronic transmission.
    Has all Option Packages that were available:
    - S-line sport package
    - Audio Package with:
    - RNS-E Navigation, Bluetooth, Satellite radio, CD Changer, DVD, BOSE speakers
    - Cold Weather Package
    - Convenience Package
    - Rear sun shades
    The vehicle has been upgraded with no expenses spared in any department, and was built right using as many OEM Audi parts as possible in order to maintain reliability. Over $20,000 spent on hard parts alone, plus tax and labour. No BS. Look up the parts yourself.
    Always maintained to the highest degree including oil changes every 6,000-8,000km with German Liqui Moly Synthoil Energy 0W40 Engine Oil, Hengst filters, etc. HPFP cam follower gets replaced every third oil change. All fluids changed recently including brake, power steering, front/center/rear differentials, and coolant. Timing belt, waterpump, thermostat, rear coolant flange, and temp sensors just replaced less than 9,000km ago. S4 air filter and charcoal cabin filter just replaced as well. New Osram HID builbs in headlights a month ago (also in HID fog lamps installed as well, in European housings). Has had Open Road Audi upgrade the intake cam with the new REV. B. as well as the HPFP replaced a couple years ago under the extended warranty campaign. If you know these engines, you can see that everything that could have an issue has always been taken care of before there is an issue.
    Performance upgrades:
    Engine, Turbo, Fueling, etc.
    - K04-064 Audi S3 OE Turbo ($1,750 plus $300 customization to fit...)
    - Audi S3 Fuel injectors ( $600 plus $100 install kit)
    - Audi RS4 LPFP Controller (to maintain fuel pressure from in-tank pump ... $475)
    - Audi RS4 PRV (to keep fuel rail pressure up to 136 bar ... $200)
    - Autotech HPFP (higher volume High-Pressure fuel pump ... $400)
    - Evolution Raceworks Dual Side Mount Intercoolers ($1,200)
    - 034 Motorsports Silicone Boost Hose Kit ($280)
    - CTS Turbo Silicone Turbo Inlet Hose ($70)
    - Go Fast Bits Machined Aluminum DV+ Valve Upgrade ($190)
    - Audi S3 DV Relocate Kit OE ($150)
    - BSH PCV Delete Kit ($150)
    - Custom Made 3" exhaust, turbo back, with Hi-flow cat, down-pipe, resonators, mufflers ($2,500)
    - Audi R8 Red Top coil packs ($100)
    - ECS Snub mount ($50)
    - Unitronic ECU Software, with stock, 91octane, 93 octane, and Custom tuned High Boost files ($1,000)
    Braking
    - Brembo Porsche Cayenne 6 piston monoblock calipers up front ($1,600)
    - Audi S4 Rear Brake Calipers ($250)
    - Stoptech Cross-drilled rotors front and rear ($600)
    - Hardware Mounting Kit for Calipers front and rear ($75)
    - Goodrich S/S Braided RS4 Brake lines Front and Rear ($175)
    - Hawk HPS Brake pads front and rear ($275)
    Suspension, wheels, etc.
    - Bilstein B8 Sprint Shocks and H&R Sport Springs ($1,200)
    - Audi RS4 OE Rear Swaybar and brackets/bushings ($400)
    - Audi TTs OE 18x9 concave wheels with machined face ($1,600)
    - Goodyear Eagle F1 Asymmetric A/S 255/35/18 tires ($1,200)
    - Hubcentric wheel spacers front and rear, including bolts ($280)
    Exterior, Interior, misc.
    - OE Clear Xenon AFS headlamps with Phil's caps
    - Clear front bumper reflectors ($20)
    - Ceramic Window Tint ($450)
    - Audi S4 OE front grill ($400)
    - Newsouth Electronic Boost Gauge and Vent kit, plus HKS filter ($230)
    - Audi S3 OE 3.5mm Aux-input to listen to iPod, etc. ($100)
    - Optima Yellow Top Battery to reduce weight up front ($325)
    - Hard-wired for Escort / Valentine radar detector and mute button installed ($30)
    - Audi Floormats replaced in April 2017 ($180)
    Audio (to be discussed, will probably keep)
    - Custom fiberglass enclosure behind factory panel in trunk for 12" subwoofer ($750)
    - JL CL-RLC 7.5volt line driver with remote subwoofer level knob in dash ($150)
    - Cooling fans in rear parcel area for ventilation to amplifier
    - 4awg power wire, speaker wires, fuse blocks, etc. ($250)
    - Amplifier and Subwoofer will be removed, but I can help you decide what to purchase
    Mileage is at 215,000 km on the body, and 170,000 km on the engine. Not a rebuild, no accidents. The car had a full re-spray in December, so the paint looks fresh and there are no door dings, etc. Maintenance is up date. Timing belt, waterpump, thermostat, rear coolant flange and fluids done in December. Cam tensioner, N205, timing chain, Cam adjuster, Valve cover and all related gaskets just done April 24th. Cam follower just done as well, but I replace it every 2nd oil change. Only 2 wear and tear items....the driver seat has the cracking lower bolster, and the steering wheel has some colour worn off on the top.
    Asking 20k Canadian, $15,500 US.
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Sep 28 2009
    suburb
    can you buy a canadian car into the US?
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Oct 03 2007
    New York
    Quote Originally Posted by flyfishing View Post
    "The car is originally a California vehicle, and is now in Vancouver, BC Canada (where I live)." I would say affirmative.
    AKA: Eightx3
    Sep 28 2009
    suburb
    ok sent PM. anyone know exactly how to import a car? is it even importing if it is originally from the US?
    Audi SQ7
    Audi B8 S5 (gone)
    May 11 2010
    BC
    All emails and PM's replied...
    Senior Member Two Rings HOJeepster's Avatar
    Aug 04 2014
    Lyons, CO
    The import process seems mostly straight forward: http://www.ezbordercrossing.com/the-.../#.V_VzXOArLRY
    Oct 06 2016
    Boston, MA
    I didnt know the k04 was capable of 350hp! Car is bad ass! GLWS.
    May 11 2010
    BC
    Quote Originally Posted by BostonMedic View Post
    The OTS Unitronic tune makes 341 apparently (not at the wheels) @20psi. I have a revised tune that's 25psi, and holds 20. Have a dynojet raw output printout somewhere. I'll post it up after I find it. Made around 300whp.
    May 11 2010
    BC
    PM's replied, and added pictures to the first post.
    Open to offers. New car on the way.
    Veteran Member Four Rings rhfosu's Avatar
    Jan 01 2015
    Alexandria, VA
    1 6MT away from absolutely perfect. GLWS.
    May 11 2010
    BC
    Quote Originally Posted by rhfosu View Post
    Thanks! I wanted a 6 speed as well, but couldn't find one when I was looking.
    On another note, the car is in getting a full resprary as per my original post. Also sent the headlights out to be refinished, and ordered new fogs to complete the re-fresh for the new owner.
    Will be done early next week.
    Jan 01 2015
    Alexandria, VA
    Quote Originally Posted by baldy View Post
    I know how hard it is. Believe me. I've been looking for a clean manual avant (at the right price) for over 2 years. I always just miss out or get outbid.
    Established Member Two Rings goneAUDIcrazy's Avatar
    Apr 26 2014
    Atlanta
    Is this still available?
    May 11 2010
    BC
    Quote Originally Posted by goneFXcrazy View Post
    Still available.
    Paint took a little longer than expected since I stripped everything off the car (bumpers, lights, mouldings, handles, aluminum trim, rockers, etc...except the roof rack) and also had the headlights refinished (look like new, no chips), ordered an S4 grill (original S-line was cracked apparently), and replaced all the clips after pulling the panels (almost a quarter of them broke during disassembly).
    Also replacing the inner drivers door handle since the spring broke, and the lower driver seat (bolster is cracked).
    Just waiting on the above to get here any day and it's ready to go. The whole car is back together, wet sanded, and polished.
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    Wow, I love your car. If you weren't on the other side of NA I might take you up on it...
    May 11 2010
    BC
    Quote Originally Posted by VroomTT View Post
    If you come pick it up, you can cross off that cross country road trip bucket list item.
    I'll post up new pictures in a couple of days once the salt is off the road here... I don't want to drive it and get it chipped up since the paint is still fresh and soft (and it hasn't been opti-coated).
    May 11 2010
    BC
    Still available. Would like to see it go to a good home.
    Timing belt, waterpump, thermostat, rear coolant flange, coolant temp sensor and fluids done in December. Cam chain tensioner, N205, timing chain, Cam adjuster, Valve cover and all related gaskets just done April 24th. Cam follower just done as well.
    Tire kickers ("What's the 0-60...is it faster than a ______"), low-ballers ("I'll give you 10k Canadian, take it or leave it....Want to trade for a ______, there's only 2 years left on the lease") and time wasters ("I'll be in town next weekend and will take it for sure....") galore on craigslist.
    Senior Member Two Rings ElSnake's Avatar
    Jul 07 2007
    01 Tial 605'd Audi S4 / B5 Audi A4 Avant BT / 17 Tacoma DCLB TRD 4x4
    Long Beach Cali
    Awesome car, looks like its worth your asking price. thanks for the replying to my WTB ad but I would be looking at b8's in that price range.
    1.8T Eliminator GT2871 Unitronic 630 Injectors Racetec Intercooler 2.5 Borla Exhaust Spec Stage 4 W/LWFW Forge DV BBS CH Reps ST Coils Carbon Fiber Hood & Trunk and lots more.
    May 11 2010
    BC
    Sold
