Results 1 to 12 of 12
    Established Member Two Rings MichaelC's Avatar
    Nov 09 2009
    2017 Mercedes S550; 2002 Ford Thunderbird
    Chicago
    Emissions Recall on 2012-2016 3.0L TFSI
    I just received a letter from AofA regarding an emissions recall on certain 2012-2016 Audis equipped with the 3.0L TFSI engine. Letter says on some engines manufactured during a certain period the diagnostic thresholds for the catalytic converters were programmed to tightly in the ECM software. As a result, a malfunction indicator light may come on even though the catalytic converters are working property. If the light's on, the car won't pass emissions inspection. The fix is to install updated ECM software. You can check if this or any other recall affects your car from the Recall/Service Campaign Lookup tool at www.audiusa.com with your VIN.
    Michael in Chicago
    Aug 27 2008
    Houston Area
    Got my notice yesterday, although I was expecting it...
    4 pages on this exact topic over on the B8/8.5 S4 forum... http://www.audizine.com/forum/showth...all-2016-09-21
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    Could this potentially cause TD1 flagging if I have the fix done? Anyone have any idea?
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Quote Originally Posted by LordMagnet View Post
    If your signature is accurate, yes.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jul 20 2015
    Connecticut
    Quote Originally Posted by HazeMyth View Post
    Mostly worried about the tune. The SA already said they were fine with intake/exhaust mods.
    Jul 17 2015
    Colorado
    Yeah, My SA said they're cool with pretty much anything but a tune, but that they prefer to know what mods are done to the car ahead of time. Exhaust, suspension, intake, etc. All of that stuff they're okay with if you're up front about it.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Aug 05 2011
    LI, NY
    If you have a tune you'll have to flash your car back to stock before you bring it in otherwise you'll get flagged TD1. Then once done have your tune flashed back. Difficult part now going forward is if you need to bring the car back in for service you'll have to get it flashed back to stock that HAS THE NEW UPDATE, something the tuners will have to have available. Otherwise they'll see something is amiss as it will not have the new update and you could get flagged TD1 cause you messed with the ECM
    2019 RS5
    2013 Audi S5 Estoril Blue - SOLD
    Weekend Warriors - '97 Mitsubishi 3000GT VR4 / '96 Mitsubishi 3000GT VR4 Spyder
    Jul 20 2015
    Connecticut
    If my check engine light stays off, I may just skip this.
    Quote Originally Posted by oohnoo View Post
    That's a great point.
    Junior Member Two Rings
    Jun 28 2016
    Wichita, KS
    Got my letter last week. Car runs great and I have no intention of letting them F with it unless it throws a code like they describe.
    Jul 17 2015
    Colorado
    Quote Originally Posted by Oldsman View Post
    I think someone mentioned in the similar thread in the S4 section that this update was only warrantied for a limited time. Might be worth checking with your service department.
    I've thought about this, too, considering the update wipes out all of your VAGCOM changes, if the technician just clicks OK to all of the reset prompts during the update.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Nov 09 2009
    Chicago
    The letter from AofA contains this statement:
    "IMPORTANT! Please note that if the ECM in your vehicle has been "chipped," "tuned," or otherwise modified from original factory specifications with aftermarket components and/or software, work need to repair, replace, or return the ECM to original factory specifications is NOT covered under this action."
    Michael in Chicago
    Jul 20 2015
    Connecticut
    Quote Originally Posted by MichaelC View Post
    If they can tell.
