Results 1 to 17 of 17
Thread: 17z Pistons
    Sep 07 2012
    Tucson, AZ
    17z Pistons
    Where are you guys getting replacement pistons for 17z calipers?? I just picked up some calipers From the junkyard and noticed a couple nicked pistons after removing the pads and cleaning them off. Hoping someone knows a decent source for these.
    Jan 01 2012
    2004 A4 Avant
    CO
    try talking to dave at zeckhausen racing, i bet he could source them for you. Curious, what did you pay for them from a junkyard?
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Veteran Member Four Rings topquarkpc's Avatar
    Aug 03 2009
    PNW
    I thought ECS sold them as well...
    '01 Imola Yellow Avant Sport Package 6-Speed (stage 3 w/Frankenturbo F4H)
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    What sizes do you need? (They're 34/36/38)
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by jjvwg View Post
    Paid a little less than $200 for both. Thanks, I'll try and contact him and see if he can get me some.
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by topquarkpc View Post
    Searched ECS and couldn't find any. Wish I had some part #'s.
    Quote Originally Posted by LINDW4LL View Post
    I am just going to replace all 12... Calipers have like 190k on them and most of the pistons look pretty beat.
    Jul 07 2009
    Alberta, Canada
    All 12?
    Be prepared to spend a pretty good chunk of change. That's 12x pistons, 12x seals, 12x dust boots.
    The process also isn't very fun at all. Getting all of the pistons out. Then getting them back in without damaging the boots.
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by LightningLou View Post
    PM incoming.
    -Hayden
    Jan 01 2012
    2004 A4 Avant
    CO
    Hmm that's not too bad, then I was hoping they wouldn't overcharge you like a lot of people on this site try to do. Reason I asked is you can buy refurbished ones off parts geek for $300 plus shipping and they are fully cleaned up with new seals, dust boots, and Pistons. Only thing missing is the crossover pipes which are an extra $50. Just wondering what you'll pay in the end to spruce yours up vs buying refurbished. Seals are pretty cheap, but not sure how much pistons cost.
    Jan 01 2012
    2004 A4 Avant
    CO
    i take that back, i guess 17z seals are more expensive than the 18z ones. This site has a pretty good selection of stuff (http://audibbkparts.bigcartel.com), but you might be able to find the seals cheaper elsewhere as it would be $100 for both calipers. god knows what the pistons cost. you might think about just cleaning up the rough spots very carefully with a file. at this point though, you might be better off trying to return them or sell them and just buy the refurbed ones on partsgeek.com.
    http://www.partsgeek.com/ss/?i=1&ssq=19-3160&x=0&y=0
    http://www.partsgeek.com/ss/?i=1&ssq=19-3161&x=0&y=0
    edit: just looked at the first link i provided up above and it appears that they no longer have nearly as much products related to the 17z/18z brakes as they used to. Also, looking at their prices it seems they jacked them up a little bit.
    Jan 01 2012
    2004 A4 Avant
    CO
    http://www.partsgeek.com/catalog/200...epair_kit.html
    heres a more reasonably priced seal kit should you rebuild yours
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    seal kit is ~$50.
    there is a seller on ebay.co.uk that sells the pistons and also the phenolic pistons.
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by jaychen View Post
    seal kit is ~$50.
    Anyone ever try the phenolic pistons? I'm sure the heat transfer to brake fluid is a lot less, I'm just worried about longevity... I can get a complete rebuild kit with phenolic spacers to service both calipers for like $150.
    Feb 19 2011
    Earth
    18z have 3 per caliper from factory so im sure they're there for a reason?!
    Sep 07 2012
    Tucson, AZ
    Yeah, but why only one side and not all 6 phenolic or just 6 aluminum? Anyone know the engineering behind this? I would be replacing all 6 with phenolic pistons.
    Btw here's the link to the kit I'm talking about:
    http://vi.raptor.ebaydesc.com/ws/eBa...=1475705159958
    Feb 19 2011
    Earth
    that i have no idea about.
    cost reasons perhaps?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Rock Auto
    34mm- $16
    36mm $4
    38mm- $16
    Seal kit $32
    $208 total, or you simply could have purchased remans off there for less than $300
    2020 SQ7- Wife's ride
    2000 S4- Working?
