Results 1 to 15 of 15
Thread: Battery Life
    Dec 03 2009
    Florida
    Battery Life
    I have a 2009 A5 3.2 bought new in Sept 09 and still with the original battery. I have no signs of the battery going bad but want to know from the rest of you how long has your battery lasted?
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Quote Originally Posted by DBS View Post
    No clue exactly how long, but my battery is technically 4 years old (Vehicle manufactured in 2012), has spent its entire life in a cold climate, and still not currently showing any signs of failure. Living in a cold climate reduces battery life because of starting in cold weather.
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Mine was a 4/2009 build and still on original battery with 102k miles.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    A lot of the battery's life is dependent on treatment. A battery that has spent its life in cold weather, has been exposed to high draws (i.e. custom stereo), and has had to be jumped will have a life that is years less than one with an easier life so to speak.
    I'm currently at 57k with no signs of weakening power.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Senior Member Three Rings ChipB's Avatar
    Nov 04 2009
    '21 BMW X5, '16 BMW M4
    Morristown, NJ
    Picked up my car in October '08, and still on original battery. I hope I haven't just jinxed it!
    '24 RS5
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    I've replaced 3 batteries since Day 1, but it has nothing to do with the battery life or quality of the battery itself.
    I've got the remote start w/ GPS module and it would drain the battery very fast when you leave the car in the garage for couple of weeks.
    But I'm glad the dealership covers everything under the warranty
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Jul 17 2015
    Colorado
    ^ What remote start w/ GPS module?
    IG: @MrHazeMyth
    Veteran Member Four Rings ak_siberian's Avatar
    Jan 30 2015
    992C4S, T2 Touareg V8, Porsche Macan S, & Gehl turbo bobcat;
    20 miles NW Fairbanks, Alaska
    Wish they would sell Varta batteries in the US. Closest you can find is Interstate since Varta doesn't ship car batteries to the US. Stay away from DieHard or NAPA batteries
    siberian
    PS I do not work for Interstate :0)
    The best long distance runners eat raw meat, run naked and sleep in the snow
    Jul 17 2015
    Colorado
    DieHard batteries were hit-or-miss for me, but I never felt like I got any benefit from the additional cost they seem to come with. Interstate has always been great for me, and the pricing is reasonable. I just wish they weren't so damn ugly! At least with the S5 the batteries are in the trunk, so it doesn't matter how ugly the battery is.
    IG: @MrHazeMyth
    Jan 30 2015
    When I test drove for Audi/VW since Varta doesn't ship to the US, they use Interstate which is why I use them and they've been great. Not the longevity of a Varta (yes,, I do live in "cold" climates) but the best I've found. As to hiding them, the Touareg batteries (in V6 and V8) are under the driver's seat :) . The monster V10 has two batteries, one in the trunk and one under the seat.
    siberian
    Oct 17 2012
    NoCal
    Quote Originally Posted by HazeMyth View Post
    Smartstart, you could find the link in my Build Thread under the signature
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Doesn't all OEM batteries are made by Varta?
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    The S5 isn't special in regard to it's battery. It will die out just like any other car. Run the battery until it shows signs of getting weak or needing a charge. For what it's worth I've changed the battery on my own A8, A8 W12 and a colleagues S8 all without putting it on a trickle charger. Simply buying a replacement battery from Advance Auto Parts, disconnecting the old and throwing in the new battery. No problems whatsoever. I did use VCDS ( Vagcom) to reprogram the new battery but that is all.
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Jan 30 2015
    Quote Originally Posted by wangshuo1989 View Post
    Yes, I was mentioning when you need to replace it, Varta does not sell car batteries in the US
    siberian
    Aug 30 2016
    Los Angeles, CA, USA
    I think our cars use the AGM battery which is supposed to last longer than traditional flooded batteries. So if you don't running the battery down all the time and don't keep it in the hot sun, it should last much longer. It also helps that the battery is in the trunk and not in the hot engine compartment. It's also why it's so much more expensive.
    Best tip I've found for a long battery life (flooded/AGM) is to keep it topped off. I have a smart charger that I connect to charge the car once a month. It's also a good time to check under the hood for any other things that need attention.
