Results 1 to 33 of 33
    Senior Member Three Rings challenger's Avatar
    Mar 23 2013
    United States
    Fuel Rail Pressure Regulator Valve - Pricing
    I was curious in upgrading my OEM PRV to an RS4 PRV or better. I wanted to see if there were any other places that people found these at a better price? I rather not put any more money into my car since I am planing to swap out for a 2.7 in the future so the least I can spend to fix this car the better. I am having fueling problems still and I have replaced everything possible(HPFP, Cam Follower, LPFP, LPFP module, fuel filter, fuel pressure sensor and the PRV. I even upgraded to a walbro 450 ahead of time to see if that would fix my car from going into limp mode every time I give it some gas in a higher gear (Highway). No CEL just a hidden code 8851.
    I'm not sure about some due to price, so if anyone has any experience with the cheaper sites let me know!
    ECS: https://www.ecstuning.com/b-genuine-...ach/079130757/
    HPFPupgrade: http://hpfpupgrade.com/Products/Show...nce+Rail+Valve
    USP: http://www.uspmotorsports.com/Engine...ase-Valve.html
    StokeAudi: http://www.stokeaudi-parts.co.uk/pro...9-130-757.html
    GarageMidnight: http://www.garagemidnight.com/produc...l-return-valve
    2013 Blue Raspberry S4 B8.5 - IE Stage 2 Dual Pulley E40
    Mar 24 2013
    Oakdale, CT
    RS4 valve is your cheapest option for an upgrade. It's a stock part and will work fine for a 130 bar tune. I have run an HPFPupgrade 145 bar valve for a few years now with only one issue. It started to lift around 110 bar or so for no apparent reason after about 2-2.5 yrs of use. The valve has a 5 year warranty and they replaced it for free. No problems since. I recently sold 2 145 bar valves for $100 shipped, so maybe you'll have luck finding a used one. I'm currently running a custom 165 bar rail valve made by HPFPupgrade and if you think the RS4 valve is pricey, you don't want to know what that one cost.
    -Adam
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Somewhat related to this thread. But would running a higher bar valve be beneficial on a stage 2 hpfp tune? I imagine only if yours is limiting the fuel?
    Mar 24 2013
    Oakdale, CT
    Pretty much every upgraded hpfp tune requests 130 bar rail pressure. The stock valve lifts at either 116 bar or 126 bar depending on which version you have. There is most definitely benefit to be had. You'll also ease the strain on your pump because it won't have to try to maintain pressure while the rail valve is lifting to try to bring it down.
    -Adam
    Jun 27 2011
    ^^ That. Theres really no downside to running a higher pressure valve. I don't think it screws with the ECU at all even when stock, though I could be mistaken..
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 23 2013
    United States
    I have a stage 2 unitronic tune and I am hoping this may be the solution to my never ending problem. I'm sure I should be more then fine with a RS4/135 bar valve correct?
    Mar 24 2013
    Oakdale, CT
    Not sure what your never ending problem is, but yes, you would be fine with the RS4 valve.
    -Adam
    Mar 23 2013
    United States
    I gave a brief description of it above. My car just seems to throw itself into limp mode with no boost for 30 seconds every time I give it a good amount of throttle in a high gear lower rpms. When I rip it from 1st to 4th WOT its fine. Makes no sense
    Mar 24 2013
    Oakdale, CT
    Have you done any logging to try to figure out the problem? Have you nailed it down to a high pressure or low pressure issue?
    -Adam
    Mar 23 2013
    United States
    I have not done any logging due to not having a VAG-COM. I did notice after changing the module it went away for a bit but also upgrading to the walbro 450 lpfp my fuel cuts went away. So now all it does is throw itself into limp mode every time I'm in a higher gear, low RPMs and give it a good amount of throttle.
    Nov 15 2011
    Montreal | I sell in USD
    ^^Might be worth mentioning, Unitronic is known to fall in limp mode if you dont use 93 or above octane if you have a tune for 93.
    *****I sell in USD*****
    Mar 23 2013
    United States
    Quote Originally Posted by Axis View Post
    Should I give them a call? I don't know where to really go from here. I've only used 93 octane since the tune.
    Nov 15 2011
    Quote Originally Posted by challenger View Post
    Even if you call them, they willl ask for logs in order to help you.
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    My issues occur at the exact same time, though mine is in the form of preignition probably from too much air and not enough fuel and i have a different tune.
    Been considering doing the PRV as well since its really the only thing that hasn't been replaced. I even had the cam recall done at the dealer a couple weeks ago.
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Nov 07 2015
    Pennsylvania
    I just something about some tunes not likeing higher valves, specifically JHM, of course I saw this after I decided to order one :(
    Jun 27 2011
    I don't think the PRV is going to solve this issue. Reason being is at lower RPMs the fuel pressure isn't even close to approaching the stock crack pressure. You've really got to log this one or else you're going to continue to play parts darts.
    Also, you got the correct High pressure sensor for the fuel rail right? there are two versions depending on what year you are (I think the split was when they went from BPG to BWT engines).
    Edit: The reason I say this is twofold. Low rail pressures usually manifest themselves as gradual issues, like fuel cuts at the upper RPMs and niggling problems. They generally don't manifest themselves as hard limp mode being initiated at low RPMs and thus low fuel pressures. The only way I can think of at the moment that a hard limp mode can happen from the fueling system is from a faulty sensor or wiring.
    -CP
    2017 Q7 3.0t
    Mar 01 2011
    Nanuet NY
    have you looked at the fuel rail sensor? you need to log to see where your issues is. HAve you looked into the maf ?
    Mar 24 2013
    Oakdale, CT
    -Adam
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    You think this is necessary for a stage 2+ jhm tune? i have an '08 so i already have a 126bar prv. Car is in pieces so it might make sense to upgrade.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Mar 24 2013
    Oakdale, CT
    If the tune requests a 130 bar rail pressure I would say yes, but you could always ask Jake.
    -Adam
    Mar 23 2013
    United States
    Quote Originally Posted by reno808 View Post
    I did replace my high pressure sensor from the dealership less then a year ago along with the pump. I would assume its the right one for my car. Also, my maf sensor was replaced maybe 2 years ago... I havnt came across any faulty wiring, I feel it would cause more of an issue wouldn't you think? I guess the only way to go is to log but I sadly do not have a VAG_COM and I dont know anyone in the Westchester area who does either. Does anyone happen to know what the requested bar is for a stage 2 unitronic tune?
    I found this on JHMs website:
    "On the B7-A4 2.0T (not the 3.2L), there was a VIN split for this sensor between the 2006 and 2007 model years. If your B7-A4 2.0T has a VIN up to 8E_6_400000, this is the part for your car. If your B7-A4 2.0T has a VIN of 8E_7_000001 and up, you need the LATE sensor. The original part number for the LATE sensor was 06J906051B which superseded to the current part number 06J906051D."
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    There's a prv available in classifieds.
    If unitronic tuned (not sure if I'm correct) I had tune issues causing fuel cuts no limp mode. It was in the unitronic tune. They later revised it correcting that issue, but caused the "underboost" code to pop up time to time.
    Mar 01 2011
    Nanuet NY
    my car was throwing all sorts of codes because it didnt have the fuel pressure sensor. i swapped my engine from an early vin into a late vin. maybe its worth investing in a Vagcom.
    Jun 27 2011
    Quote Originally Posted by canadianA4B7 View Post
    TL;DR: Unitronic is shit.
    -CP
    2017 Q7 3.0t
    Mar 24 2013
    Oakdale, CT
    Up to and including stage 3 tunes.
    -Adam
    Mar 23 2013
    United States
    When was this? I got my tune maybe 2 years ago? I wish I went JHM but stage 2 wasn't out yet
    Also, this may be a dumb questions but whats the difference between these 2 parts?
    https://jhmotorsports.com/shop/catal...32l-p-726.html
    https://jhmotorsports.com/shop/catal...si-p-2278.html
    Feb 21 2015
    Rip City
    One is low and one is high pressure sensor.
    Low pressure sensor goes on the HPFP, High pressure sensor goes on the fuel rail.
    Feb 16 2013
    So.Cal
    ^^^ LFPS installs on the high pressure fuel pump, reads FP before fuel gets pressurized. HPFS installs on the fuel rail and monitors high pressure.
    Mar 23 2013
    United States
    I think that's the only fuel related part I haven't changed. What codes would that throw on?
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    I also think the tune is the problem. When you go WOT at low rpm, what rpm are you talking about. I never go WOT below 3 to 3.5k rpm. Otherwise I feel like I would be lugging the engine which doesn't help bearing life.
    I don't understand how a higher pressure prv would help with your problem. Aluthman and Charles correct me if I'm off base, but all the prv does is maintain the pressure in the fuel rail (available to the injectors) at a prescribed level, and relieves the excess pressure by lifting until the pressure drops to the prescribed level. It's all mechanical. It should do this at all rpm levels from idle to redline. The pressure sensor measures the rail pressure and trips a code if it is not being met either due to a clogged fuel filter, malfunction of the LPFP or HPFP, or a faulty prv, etc.
    Theoretically, the stock system should be able to meter fuel at the prescribed pressure up to redline. The so-called "upgrade" HPFP would not help the stock tune system, and a higher prv pressure wouldn't either although the higher rail pressure might result in a slightly better injector spray pattern. At higher rail pressure the injectors would be capable of delivering a greater volume of fuel, but in a stock system the spray impulse duration would be electronically shortened by the ECU. Otherwise, you'd be running too rich a mixture. The point here is that the higher pressure wouldn't be affecting the volume of fuel supplied to the cylinder at any rpm.
    Having said that, a tuned system is capable of delivering much more air to the cylinders due to the higher boost pressure recipe of the particular tune, which is where the horsepower increases come from at higher rpm. Therefore, at higher rpm the ECU would be calling for longer injector pulse duration to achieve the correct fuel/air ratio. This mandates a higher fuel volume than the stock HPFP is capable of delivering. As I understand it, all the "upgraded" HPFP does is deliver a greater volume of fuel, again, at the prescribed pressure. The HPFP does this by simply increasing the diameter of the pump piston. I believe the APR pump piston area is 30% greater than stock (don't know about the other HPFPs on the market) which should meet the fueling requirements at the highest rpm and the highest boost pressures. I can see that a higher rail fuel pressure might help the situation of the tuned system at the higher rpm levels until the capability of the injectors is exceeded, which I believe is why some of the higher tunes required the larger fuel injectors (S4).
    The down side of higher prv is as follows: 145 bar is about 2100 psi. The diameter of the HPFP piston is about 0.3 inches. Therefore at 145 bar the fuel is pushing back against the piston with a force of 150 pounds plus the 20 pounds of the HPFP spring pressure equals about 170 pounds force. This is the same force transmitted to the cam/cam follower junction. The "upgraded" HPFP force would be 213 pounds of back pressure. A 165 bar prv would be about 240 pounds of force with the higher capacity HPFP. That's a lot of contact pressure between the cam follower and the cam. Check your cam followers often!! The stock system would be about 135 pounds of force calculated using a fuel rail pressure of 115 bar.
    Sorry to meander around the subject but would appreciate any comments or corrections on the above logic.
    Nov 07 2015
    Pennsylvania
    Couple of things brillo. Firstly most upgrades use rs4 or s3 injectors not s4 also I believe many bt setups utilize the rs4 prv at 135 bar so I don't see an issue with running a higher one, however I do believe that if you have a higher bar valve you should check your cam follower often to stay safe.
    Mar 24 2013
    Oakdale, CT
    Brillo,
    You pretty much hit the nail on the head. The upgraded PRV and HPFP will do nothing on a stock car. The need for the upgraded PRV comes when you get a stage 2+ tune that requests a higher rail pressure from the higher output pump. These two factors combine to provide adequate fueling for the increased airflow to the engine while still using the same injectors. But when your HPFP is trying to achieve 130 bar rail pressure and your PRV is opening to try to limit pressure to either 116 or 126 bar, your HPFP has to try to pressurize a leaking system. This increases the strain/wear on the HPFP and it's solenoid. I'm not saying the OP's issue isn't caused by his tune (because Unitragic tunes blow donkey balls), but merely that his setup will see a benefit from a higher rated PRV. You are also absolutely correct about CF wear increasing. A stock car can go 50-60k miles on a CF pretty easily, but with my HPFPupgrade stage 1 pump and a tune that requested 130 bar, I was changing them every 7500-10k miles. If I went much beyond 15k miles, I would probably burn a hole in the CF. It's just the price you pay to get more power out of these engines.
    -Adam
    Mar 23 2013
    United States
    In that case it can't be anything else but the tune? I mean I have changed every fuel related part and regardless if it works or not, I already ordered an rs4 prv just to get it outa the way. I hope it's covered under warrente of the time. I'd hate to have to spend anymore money on this damn car.
