UPDATE TIME
Hopefully I can get some more help
I put the O2 sensors back in and got rid of 3 of 5 codes but I am still getting
P1426 Tank Ventilation Valve Open
P0154 HO2S (Bank 2 Sensor 1) Circuit No Activity
Im guessing the P0154 is from a bad O2 pin and im going to try some contact cleaner on it.
Now I know for the P1426 code
rollerton said this stuff is associated with it: "Tank Ventilation is the EVAP system, includes the little N80 valve by the airbox, plastic hoses to the tank, the stupid pump and valve etc..."
I deleted the SAI and also I have a plug that is going to nowhere. From what I can tell the plug to nowhere is supposed to connect to the N80 valve.
Am I wrong to assume that this is the reason that I am getting the P1426 code? I mean shouldn't all of this have been tuned out to not throw codes since it is all connected?
Also do you think if I can find the N80 valve(if I still have it
) and just plug it up without it actually going anywhere that the code will go away?
