Results 1 to 40 of 70
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Project Winter Beater
    Picked up a pretty clean ebony black 01 1.8tqm for $300 Canadian pesos over the weekend with engine damage. Abit of rust and no sunroof.
    Plan is to get it running so I can park my clean modified a4 for the winter. Thinking of swapping my engine+trans out of my good car as I know it's reliable.
    Rented a uhaul to go pick it up. My brother Inlaw towed for me cause I have yet to get a hitch for my 3/4 truck.
    Got the engine torn apart to find timing was off about 6-10teeth.
    4:
    3/2:
    1:
    The cylinder head has chunks missing so that is beyond repair.
    Bits of metal I took out of cyl one with a magnet.
    But the cylinder walls are fine so I can use the block to build my 2.0t that I am planning.
    As it currently sits. Not sure what to do right now. Thinking about taking my aeb engine apart that needs rings and putting that head on this 06a block.
    Sent from my Jailbroken iPhone 6s iOS9.3.3 using Tapashit
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    Yes! Saw this on Instagram. Following this!
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    Nice find King. Looks like a great project. Better get it running soon though, winter is coming fast for you. We're still wearing shorts on the West Coast
    Is that an eBay chin spoiler or the very rare OEM?
    Following this build for sure.
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Good find, get her done
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    Man that engine ate itself really good. Following on IG and here!
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Oct 09 2012
    Been a while since an update cause not much has happened.
    Poped my aeb head onto the damaged block to see how it was doing and the non damaged cylinders have lower compression then the damaged one so pulled the engine+trans out to build my 2.0t out of the block. Trans looks leaky too that will reseal it and throw it back into the beater and save my lower mileage trans for the 2.0t.
    And it's all out.
    Had to bend the alternator bolt to get the alternator bolt off as the clutch fan bolt was stripped.
    Removed the steering wheel cause it's mint and put it into the eh four.
    So I guess I am going to reseal the beater trans and swap in my good engine out of the eh four.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Dec 05 2007
    I have old awm rods with original pistons still together, along with unused rod bearings laying around. Swap out that one cylinder by simply dropping pan (and undoing rod from crank), pop out assembly, and drop replacement in. I suggest you don't trust the rings on units I have, but you can use them at your own risk. They should be fine still and quick 3-5 second hone will make them work fine. Let me know!
    Edit: reading comp 101. looks like you already have a game plan
    Oct 09 2012
    Quote Originally Posted by Pringle420 View Post
    Thanks, It is a cheap ebay chin. Going to swap on an OEM one.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Veteran Member Four Rings reece_2212's Avatar
    Apr 22 2016
    Alberta, Canada
    Quote Originally Posted by King_ View Post
    Wanna sell me the cheap one when you swap em?
    '96 A4 2.8QM - (RIP Avocado) <3
    '01 A4 1.8tQM - GT2860RS Elim, 550cc, APR Carbonio, Clutchmax Stage 2 w/ SMFW, APR FMIC, IE Rods - Bilstein B8, Tein S Tech, 034 Trans Mounts, ECS Poly Snub, Stern Engine Mounts - B7 A4 Front Brakes, C5 S6 Rear Brakes, Stoptech Stainless Lines - eBay SS, 3D Printed Shifter Cage, JHM Linkage Bushings -
    May 10 2015
    Pittsburgh PA
    Looks like you'll have yourself a relatively clean daily once you swap in the good engine How's the interior?
    Unrelated to this car, but I noticed in your sig you have an eBay short shifter in your "Eh Four". How do you like it? Is there any slop in the shifter, or does it feel pretty solid?
    S-Line converted | A7 356mm BBK | OEM 19x9" A8 wheels | Spec Stage 3+ Clutch | ECS LWFW | IE 3" downpipe | CTS catback | IEStage2+JB4 Stack Tuned | Meth Injection and more... +
    Oct 09 2012
    Quote Originally Posted by 19birel View Post
    The interior is pretty clean. Common seat rip. Will get some pics tomorrow.
    Going to start tearing apart the eh four tomorrow. Thinking about swapping in a v8 since it is alot cheaper. about 1/5 the price of a 2.0T build.
    I am going to make a thread about the shifter since I get asked so much. watch for it.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    May 10 2015
    Pittsburgh PA
    V8 swap would be pretty sweet, but probably wouldn't be as fast if speed is what you're after. It definitely wouldn't be slow though, and it would sound amazing.
    Oct 09 2012
    The v8 is gonna happen. Always wanted one. Almost bought an 06 s4.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    May 10 2015
    Pittsburgh PA
    Nice
    In that case, will you be swapping the K04 setup into this car too?
    Oct 09 2012
    Nice
    Yes the EH FOURs 1.8, trans, front axles, headlights(for now), k04 and exhaust are going onto this car. May save the stern engine mounts for the v8, get some s4 ones or something for this. gonna install my subwoofers and bt headunit aswell.
    scratched the beaters rear bumper opening the garage door. hopefully it buffs out. such a noob move.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 09 2012
    Got the beater stripped down ready for its new 1.8t. Probably gonna leave all the oil on the subframe cause rust prevention. Lol. That or spray some rust paint on the rusty bits.
    Got the EH FOUR pulled in and bumper off.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 09 2012
    I got the engine out on the 13th and I fucking hate turbo studs/exhaust nuts. I have had nothing but problems with them. Gonna double but the cat to turbo this time around. Not dealing with those stupid fucking locking nuts.
    The nut snapped the stud on removal and then I had to drill the fucking stud out.
    Retapped the turbo stud holes and got the new studs in. I hope the remaining threads hold.
    Got the cars shifted around ready to drop the engine into the beater. One of the front wheel bearings are bad though so have to drop the top control arms to drill out the pinch bolt.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 09 2012
    Engine is in and ready to start.
    Pulled the driver knuckle cause the bearing has play. Had to drop the whole front corner to remove the pinch bolt with an air hammer. Completely destroyed the abs sensor trying to remove it. Gonna order a new sensor off eBay and a wheel bearing tool aswell.
    Still have to remove the case. Spent the night thinking of how to get it out and I have an idea.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    buy a harbor freight press, fuck the wheel bearing tool.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    May 10 2015
    Pittsburgh PA
    Nice progress man! I'm pretty sure Autozone or Advanced Auto will rent you the bearing tool for free btw
    Oct 09 2012
    It's all together and I have been driving it the last two days. Swapped in the front knuckles off the Eh Four. Also swapped in a partial facelift single din console. Have abunch more things to button up.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 31 2015
    Victoria, BC
    Good work.
    So I guess you can go S4 uprights in the Eh Four in prep of the big brakes your going to need to slow that V8 monster.
    Build Thread HERE
    Oct 09 2012
    Good work.
    Thanks. It's good to b5 again.
    Both front wheel bearings ended up being bad so swapping them over was the best option. It also needs a rear wheelbearing and a rear caliper(for park brake) and it will get that stuff when i park it for summer, after I swap it off from the eh four.
    Yep the 4.2 a6 came with aluminum uprights and s4 hp2 calipers so gonna strip it of the good stuff before I scrap it.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Active Member Two Rings kjames1270's Avatar
    May 16 2016
    New Jersey
    Hey car is sounding mint 🚜 I already have the hp2s. Just wondering if all C5 a6 uprights will also work?
    Sent from my A0001 using Tapatalk
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by kjames1270 View Post
    Depends on if Steel or Aluminum. If steel, it will bolt right up with HP2 brakes. If aluminum, you need the proper straight front lower control arm
    Sent from my SM-G935W8 using Tapatalk
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    May 16 2016
    New Jersey
    Quote Originally Posted by Bordom View Post
    Oo ok thanks for the help. I'll probably go steel then just for simplicity and availability
    Oct 09 2012
    steel only came on early?s4s and a6s only had aluminum. so for availability its gonna be a6
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    May 16 2016
    New Jersey
    Appreciate the help. I've been searching for s4 aluminiums the whole time
    Nov 04 2012
    Reno
    Just find a B6, aluminum.
    Late S4's are al I believe.
    Dec 10 2013
    Quote Originally Posted by RENOxDECEPTION View Post
    Late S4 are steel
    IG: 24_et
    Sold:
    RIP:
    Nov 04 2012
    Reno
    But they switched exclusively to al on the b6, so why would they go back to steel?
    Oct 09 2012
    Got a skidplate for a $20 food bank donation from picknpull. And an 034 breather toob kit for $4.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Jan 18 2016
    PA
    $20 for the skid plate tho is that metal?
    Jan 18 2016
    PA
    Looks to be I'm kind of upset if it is that's a steal
    Oct 09 2012
    Quote Originally Posted by MarcRogers View Post
    It's a $350cad Thor skidplate. And $200cad 034 breather hose kit. What a good birthday it was.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 09 2012
    Picked up a sheet of some fancy bargain bin aluminum for to make a heat shield for the turbo manifold, maybe coil packs too.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 09 2012
    Got a bunch of parts for 50% off today from pnp. All four rotors, recently replaced two reman looking front calipers and a reman looking rear passenger, A recently replaced fuel pump, both front windows, Tinted darker then what's on there right now, panel for either the eh four or beater. What ever one is better goes in the eh four. Two headlights for the beater with all broken tabs. Should be able to make them work and only $30 for the pair is perfect for the beater. Someone was taking the pads as I went back to my car for the tools. :( still have to go back for the passenger seat cushion.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    Did you swap this to the EH 4? Does it rattle like a pos rusty bucket with the Stern mounts? I just put on a Dieselgeek skid plate with 034 mounts and it's driving me fucking insane.
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    Oct 09 2012
    Quote Originally Posted by HUFset View Post
    My EH FOUR came with a THOR skidplate, and it Never rattled or made a noise with all the upgraded mounts. It is not making a sound on the beater either with the same mounts.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 09 2012
    Made a heatshield. Was hoping to make it so it protects the vcg but the manifold runs right into where the oil line used to bolt up at. Gonna try a go at a v2 to protect the vcg one of these days. Also have a new vcg on order. Seems every 20k kms like clockwork it needs one. Gonna paint the cover this time around too.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
