Results 1 to 7 of 7
    Apr 16 2016
    Kitchener
    2001.5 B5 S4 Valve Cover Gasket Kit
    Hey guys do you know how I can get a cheap Valve Cover Gasket Kit Similar to the one from ECS Tuning?
    ECS Kit includes:
    •Valve Cover Gasket Sets - Left & Right
    •Camshaft End Cap Seals - Two
    •Camshaft Seals - Four (Two Front and Two Rear)
    •Camshaft Chain Tensioner Gaskets - Two
    •80ml Tube of VW/Audi Specification Sealant
    Here's the link also
    https://www.ecstuning.com/b-assemble...kit/078996025/
    But they are asking 95 USD + shipping for me since I live in Canada.
    Does anyone have any contacts where I can get the same kit for less?
    Thank you
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    Make sure the camshaft seals you get have the rubber edge that goes around the shaft itself. I've gotten some that were paper-ish type and they all leaked within a few miles.
    Apr 16 2016
    Kitchener
    Hey thx for feedback. Is there a kit you recommend that has the rubber edge? Should I stick with the ECS kit then? I don't mind paying the extra if it's critical for a good seal.
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    make sure to silicone the edges and corners too....just s little bit...call me crazy but in my experience its worth it
    2008 Ibis RS4....GETing tuned
    Dec 30 2009
    Any of the kits I linked will have the correct cam seals.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Aug 06 2008
    Canadia
    Brand is the most important, i just replaced my 2 year old VCG again because they were leaking. Using febi, will see how they do.
    old ones were a brand that was a 3 letter acronym like GMB or something, totally useless.
    Elring or however its spelt would be a solid choice, they just werent available locally and was told febi should be fine but i'll see for myself...
    the B5 S4 is like the mafia... there is only one way out!
