Up for sale is my beloved and babied 2001 Audi B5 S4 Stage 3 Manual. She has 102K+ Miles. She has been garage kept most of her life. She is CLEAN inside and out and by the very literal definition of clean, you could eat off on this motor. Oil changes every 3K miles. No CEL. Clean CARFAX. No rust, was a Florida car for most of her life. She has had all up to date maintenance less than 5K miles all new seals valve cover gaskets, gates racing timing belt, thermostat, crank seal, Input seal, rear main seal, new clutch, yada, yada. She also comes with various extra parts as well as a spare motor that has a little over 80K mi. She is dressed to impress. Located in Virginia Beach.
Engine/Drivetrain Modifications include:
-Tuning by SSP Peaks 23 PSI tapers to 21.
-ABT K04 hybrids
-Baileys Diverter valves
-Bosch EV14 550cc injectors
-Euro spec adjustable fuel pressure regulator set at 5 BAR
-Hallman Gunmetal manual boost controller set at 23 PSI
-ECS fuel pressure gauge
-Brand New OEM fuel filter
-Bosch 005 fuel pump
-AEM vent wide band gauge
-VDO vent boost gauge
-AWE Downpipes
-Borla full cat back performance exhaust
-Joey modded airbox
-85mm ASP MAF housing with Hitachi sensor
-AWE side mounts with fiber glass shrouds
-034 EGR/SAI delete block off plates
-034 snub mount
-034 solid trans mounts
-Stern solid motor mounts
-Fully built JHM transmission Carbon synchros and upgraded 1-2 shift collar
-JHM Solid Linkage upgrade with Delrin stabilizer shaft bushing
-JHM Solid short throw shifter
-Brand New Stage 4 6 puck FX400 clutch with RS4 pressure plate and TTV single mass steel flywheel (less than 2000 mi)
-Brand New clutch master and slave cylinder
-Recently changed rotors/pads
Suspension Upgrades:
-Hotchkis front and rear sway bars
-Brand New Uro front upper control arms
-Solowerks coilovers
Aesthetic Upgrades:
-RS4 front grille
- Ecode euro clear side marker headlights
-LED exterior lights
-Porsche aluminum oil cap/coolant/washer fluid caps
-Piano black 3M wrapped belt line trim
-Beetle front headrests
-Thule aero blade roof rack
-Brand New 18x8.5Fx10R Mustang Saleen SC wheels
-Brand New 205/40-225/35 Nankang AS-1 Tires
-Fresh painted HP2 brakes with S4 badge
The bad:
It is a 15 year old car so expect some issues. Paint could be touched up to make her practically perfect. The front bumper needs a respray and hood has rock chip spots, nothing big no dents. Front fenders need touching up from some rubbing. Personally, I am okay with her paint as she stands but to each his own. LCD hud on instrument cluster is out. Small tear in driver seat bolster that I patched up. Slight sag of rear headliner. All minor imperfections.
Overall she is a reliable quick daily setup. Have yet to dyno her but my tuner says she should be in the 400-430 range awhp/tq. Interior 8/10. Exterior 8/10. The car is ready to go 60k+ miles no major maintenance. I have put over 10K into the car and she is running GORGEOUSLY. If you come by with money I will take you for a ride, no joy riding. Car has clean title in hand no lien. Im probably forgetting a few things but this is a good majority of it. Getting rid of her for the extra cash as my family is expanding and I will be leaving for deployment very soon. Asking 10,000$ Phone number is (8130 785-4659, you can PM me but text is best! Thanks. -Brandon
