Results 1 to 7 of 7
    Front Brake Calipers From a B8 S4 $500 + Ship
    Genuine OEM brake calipers removed from a B8 S4
    Aug 17 2015
    California
    Are these better preforming than the stock A4 calipers? Would I need bigger rotors?
    You would need stock S4 rotors to complete a OEM bigger brake kit. We have a set of good condition used rotors for a few extra $ if you are interested. The rotor weight makes shipping a lot more expensive, so it may be cheaper/easier to source a new set of rotors locally.
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    Functionality wise, the caliper is the same as the A4. Cosmetic wise, the finish is smooth (and black) with the S4 placard. They do use a different caliper bridge which repositions the caliper further out which will require the larger 345mm S4 rotors. You will also need to confirm that your current wheels will fit over the larger diameter set-up. I just did these on my Avant and I'm quite pleased with the added braking and the appearance.
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    PM sent
    Aug 02 2015
    Corning NY
    Your inbox is full man. Shoot me a message after its cleared out
    No more PMs please. Just email [email protected] My box gets "full" after 4 messages. I have to contact an admin.
