I have posted in a couple threads, but wanted to create a consolidated thread and ask for some advise.
Details on the car and mods:
2015 S4 with ~16k miles
EPL Dual Pulley + DSG
ECS Intake
AWE Touring + Stock Downpipes
Starting earlier this year, I began experiencing intermittent sputtering issues while EPL Stage 1 with DSG. This would only occur when I rolled on the accelerator at higher RPMs (usually above 4k RPMs) and last a couple hundred RPMs. No codes were ever thrown.
Prior to going Dual Pulley, the plugs were changed and the dyno tuning went well (at EPL). At the same time this was installed, I also had the HPFP installed.
After going DP, I started to experience sputtering again, a bit worse and at lower RPMs. Still no codes. Had the plugs changed again and changed all coils, but the issue continued.
Then, a couple months ago, I threw a CEL and EPC with Cylinder 1 Misfiring. I thought, finally, we have a place to start. This turned out to be a bad fuel injector. Injector replaced and reverted back down to the Stg 1 file. All was ok for a bit, but then EPC came on again with Cylinder 2, 4 and random misfire codes. Cleared these and car drove ok. Keep in mind here, there was no more sputtering once I dropped down to Stg 1.
Two weeks ago, I threw another CEL and EPC with Cylinder 5. This turned out to be another fuel injector. This was replaced and I threw in some Techron (wanted to use BG44k, but this wasn't available locally - might order this next) when I picked the car up yesterday.
During my drive home, again throw a EPC with Cylinder 4 Misfire (no CEL). Also, when I was reviewing the codes, I noticed a P310B Low Pressure Fuel Regulation code. However, the Fuel Pressure code was triggered in the morning (close to when I added Techron, but it is likely this was 10-15 minutes before Techron was added) and the misfire was during the evening commute.
So, here we are now. I am not sure how best to proceed or what I should start swapping. I have considered that there might be an issue with the cats, maybe the Pressure Control Value, maybe the LPFP (although the fuel pressure code is new and I have been experiencing sputtering / misfire long before this code).
Is there anything I am missing here? Anything I should be looking at?
P.s., Tony and Chris at EPL have been helping me through this the entire time (since May). We have done a few remote sessions and I send them all of these issues. I feel bad drowning them with all of this and since they are not local, I am using a shop near me to work on the car, thus this post to help point the shop in another direction.
