Results 1 to 2 of 2
    Senior Member Two Rings ASneakyGoomba's Avatar
    Oct 05 2011
    Kalamazoo MI
    Broken Battery Clamp
    Hey guys,
    I changed my battery the other day because it was five years old and no longer very healthy/ had a lot of corrosion around the terminals. The Positive clamp that goes around the battery post has corroded so much that it is a hair from completely breaking in half. It currently stays tight enough on there for everything to work fine, but obviously this needs to be replaced. Do you guys have any suggestions on what to do? I have replaced a positive clamp before on our John Deere with a clamp that I bought from Autozone, but I am a little more hesitant about cutting the massive positive wire on my Audi. Is this something I should let a shop take care of or is it not that big of a deal?
    Thanks in advance,
    Will
    Nogaro Blue B6 S4
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    it's actually the same thing.. just make sure the terminal is connected well, try to get a clamp type terminal, and clamp it tight, and you should be good to go
    Sent from the S that used to tap
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
