hi I have a 2003 b6 with a 2004 BES/BEL 2.7t engine init ,seemed to be running fine went out the other day and it started to chuck and jump around then no revs ,turnt it off restarts fine ,idles a little high at 1100 rpm but when u rev it wont go past 1700rpm,keep trying it and every so often it wil start and rev fine till u turn it off then it will just do the same ,no fault codes ,ive replaced coolant temp sensor,crank sensor and cam sensors ,I realy don't know what to do could it be throttle body I'm out of ideas
PLEASE HELP
