Results 1 to 40 of 77
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    AMD vs Ringer racing clutch
    I am thinking about doing another build. Looking for a clutch that will take a solid beating at 600+whp..
    Looking for facts and actual experiences..
    Hows pedal engagement? High? low? How long have you ran it? etc
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Southbend - No i don't have one, I have a JHM B7 RS4, however I've heard first hand from someone who has had an AMD & southbend, they prefer their Southbend. AMD fanboys will say there is no better clutch than theirs.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    May 11 2013
    Nnj
    south bend is a 4 or 6 puck correct at that power level.? how is the engagement and mileage?
    May 16 2008
    WA
    Just installed an AMD "Stage 3+" in a new RS6 project car with a refinished factory Dual Mass flywheel. Finished the initial bleeding of a new slave yesterday but the build itself isnt yet buttoned up yet to know for sure. So far the pedal feel is surprisingly light, and the engagement is predictable. Although I have only moved the car in and out of the shop thus far and on and off of the lift. So I cannot give a full blown evaluation. However, thus far I am presently surprised as I was fearing it would act more more like what is found on traditional grabby 6 puck clutches (granted the AMD is an 8 puck).
    Once I get the chance to wrap everything up and put some actual road miles on it, I will be able to give a better real world review of my experience.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Clutch threads are like oil threads... everyone has their flavor and most of it is all anecdotal to boot.
    I don't think you can go wrong with any of the popular/tested kits out there, most failures will come from driving style and abuse....
    Nov 16 2009
    Sandy eggo
    I agree people will always Jock their brands. I am more interested in real life data and numbers being put down with that particular setup. Engagement, power capacity, smoothness. Longevity and other shit is subjective..
    For instance: my FX400 6 puck held up to all the abuse(100+ launches/NLS) I could throw at it with a maxed out k24 car on E85 W/stock block. Ball park ~500whp for just shy of 30k till my 3rd gear took a shit.. Pedal engagement was at the top, and sometimes when doing log runs the pedal would stick half way after the WOT pull in 3rd..
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    3 liter car, 770's, built heads, 3 pumps with larger lines, 679whp running a ringer racing stage 4 plus clutch with light flywheel. Pedal pressure is light but not TOO light (IMO), engagement is smooth most of the time (shudders a tiny bit here and there but very minimal) and has held up for the 1400 miles that its been on the car (1000 of which were break-in miles). We'll see how it holds up long-term. I would not be comfortable launching it.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Nov 16 2009
    Sandy eggo
    Quote Originally Posted by TighTT View Post
    Nice!! Turn up the booooost!!
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    I have an AMD stage 3+ on my K24 stock block. The pedal feel is pretty much identical to stock which is really nice. It's engages pretty high up but I like it like that. It's mated to a TTV flywheel. It makes some noises down low in the rpm range but I guess that's normal. It's also VERY grabby. Only done 4 launches. Held up fine, clutched bogged one of the 4 times. So far I dont mind it though
    Nov 16 2009
    Sandy eggo
    I prefer high engagement too, are you running E85?
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    I just bought the stage 4 today. How long did it take for you guys to get yours from amd?
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    Quote Originally Posted by rguil View Post
    I had my amd stg 4 in a few days. Drop shipped from clutchmasters.
    Dec 17 2014
    San Diego CA
    Quote Originally Posted by y3ti View Post
    wait, amd clutches are clutchmaster clutches? is it just a fx400?
    May 25 2014
    Long Beach, CA
    Not exactly sure, but I think it's a custom clutch made to AMD's specs.
    The shipping label shows it shipped from CM in CA.
    Nov 16 2009
    Sandy eggo
    whoa, interesting..
    Shit if thats the case I might as well source a LUK B7 RS4 kit and run the TTV flywheel with a custom disc and save myself a few bucks..
    May 25 2014
    Long Beach, CA
    I believe the AMD is a modified B7 RS4 PP. So a stock B7 RS4 PP won't have the same clamping force.
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by Shhmaudi View Post
    36psi and counting.
    50% Blood
    50% Sweat
    Sep 11 2009
    NE
    AMD are custom made by CM. They modify B7 RS4 PP to work with B5 FW and at the same time they tinker with diphragm to get more clamping force, presumably at the expense of total travel so I think they simply change pivot point.
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Quote Originally Posted by julex View Post
    Correct. They started as a Luk, then go to ClutchMasters to be modified to whatever specs AMD specified. Not 100% sure on the details but clamping force is definitely increased, as well as whatever friction material you decide to go with.
    The Ringer Racing is also a private label Clutch Masters clutch package from my understanding. Not sure what it starts as though.
    I think at this point I've had more AMD clutches than anyone in my cars. The S4 had an AMD stage 3 clutch put in at 105k. TOB plastic failed at around 150k. Clutch still looked like it could have gone a couple more years. So I replaced with another AMD stage 3 clutch. At 182k now on the s4 and it still feels great. Changed my commute so I won't be sitting in as much traffic, so I expect it to last a bit longer than the last one.
    When I bought my RS4, it already had an AMD stage 4 clutch in it. Definitely more grabby and aggressive than the stage 3 clutch. That exhibited some kind of weird behavior after about 20k miles on it. Wasn't sure what it was so we replaced the clutch, and all the hydraulics since the trans was going to be out. It now has an AMD 3+ I think. Way more streetable than the 4. Recently broke it in and it feels great just like the clutch in my s4.
    Also had a SB clutch in my A4 back in the day. Don't remember which one it was but it was fine for k04 1.8t power levels. The engagement was different than stock, where as the AMD clutches feel like the stock pedal.
    Dec 17 2014
    San Diego CA
    Anyone know how amds 6 puck friction material compares to other 6 puck material on the market? I was cheap and bought the project b5 6 puck clutch last time and parts of the friction surface broke off after only 2000 miles. Dont want that to happen again
    May 11 2013
    Nnj
    anyone have experienced with spec 3+ ?
    Dec 03 2009
    PNW, Washington
    I can assure you they are not the same. Launched mine, flat shifted it. It held everything just fine.
    Nick from project B5 always pops into threads and talks about how great their clutch is, but I've heard more bad than good. Of course he is going to talk it up because it's more money in his pocket if he makes a sale. So I think the saying you get what you pay for applies here.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Quote Originally Posted by Mark00s4 View Post
    Ive put 2 in, 605 and 770 cars. EPL recommended them. These are the b5 3+, not the less expensive conversion 5cyl 3+.
    They are nice driving clutches and seem to be going the distance. The 605 car is a dd and was put together like 4 yrs ago, 770 is prob 2yrs.
    They are smooth in normal driving, but get grabby if you heat them up. Not terrible, but stop and go traffic might be annoying.
    Spec also gets a pretty bad rap when it comes to customer service.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Dec 17 2014
    San Diego CA
    Yeah, the project b5 clutch it isnt bad for 150$ if you just want to get down the road
    Sep 07 2012
    Tucson, AZ
    Ringer stage 4 here and holding up great so far to about 500whp. Very consistent clutch feel and not too grabby at all which I like.
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    Mike Hood is a good friend of mine but I cannot say I've installed or drove any of his clutches. However, I have installed and drove plenty of AMD clutches (stage 2, stage 3, 4 stage 3 plus's, and two stage 4's). My favorite out of the bunch was the stage 4 with the sintered iron which is a 6 puck. The 3 plus is a 8 pad and is my next favorite, 9 launches back to back and didn't slip once but had to stop because the rear diff exploded (605.2's, 36psi, E85). It's a good idea to do a clutch stop but we never did it.
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by Turbo Nerd View Post
    What makes the stage 4 your favorite? How does it drive?
    50% Blood
    50% Sweat
    Nov 16 2010
    WetSide, WA
    I would guess terribly as a daily. Ive only played with the 8 puck, and its grabby as hell.
    Established Member Two Rings sxC's Avatar
    Feb 12 2013
    2000 S4, 2012 S5
    Santa Monica, CA
    Quote Originally Posted by getslideways View Post
    The AMD 3+ feels as easy as stock when installed. Also have the USP metal slave. RS6 turbos, so far no slipping under WOT. Engagement is at the top and is near-instant.
    Nov 16 2009
    Sandy eggo
    Thanks for the clarification, I thought they modified the PP but wasnt sure.. Makes sense, since the 3+ can hold 825ftlb to the crank
    36psi and counting.
    you on 93 pump?
    Great info guys! I am really considering the AMD 3+ kit.. However, that being said I reached out to clutchnet and they are able to modify the B7 RS4 PP to increase clamping force and pair it with a 6 puck sintered ceramic disc.. After adding it up, looks like it will be ~$625 if I get the LUK repset off rock auto for $148 shipped, which leaves me with a difference of ~175 to throw at a TTV FW. I guess at this point the question is.... Play it safe and go with tested/ proven or blaze the trail and save a few bucks and give clutch net a run?
    Anyone have any experience with clutchnet in any of their builds audi or not?
    Nov 16 2010
    WetSide, WA
    Have you hit up jhm to see what their b7/stg4 is good for? If the stg4 will do it, it drives way better than any ceramic disk ever will.
    Price is good, mileage is good, and they drive dang close to stock.
    The amd is going to be grabby just like the fx400.
    The pp does make the pedal and engagement point better, and the sac will help get more miles out of it though.
    Nov 16 2009
    Sandy eggo
    Quote Originally Posted by zillarob View Post
    Yea I browsed the JHM website and it looked like it was a couple hundo more than the AMD value.. On this round my main goal is to get a clutch that will hold everything I can throw at it like my FX400 did but I want a better pedal feel and I think the modified B7 Rs4 with a SAC mech will help out with that.. I dont really mind the grabby/pucky feel as I have gotten used to it and was able to get pretty good mileage out of it. (shy 30k and just now starting to slip on NLS 2nd-3rd) I would like to get at least 30k out of this next clutch whatever it will be.
    Peter you think I could pull 60k out of a AMD 3+ unit w/ around 600whp? I'd probably hit the drag strip once a year.. rest will be street launched, NL shiftin, BMW slayin, freeway lambo roll racin
    Nov 16 2010
    WetSide, WA
    A couple hundo $$ more, or couple hundo ft/lb more?
    If $$, it comes with a fw.
    If ft/lb, then its a no brainer.
    Does sound like the way drive you will be best off with a ceramic. They are usually pretty bulletproof and handle whoopins well.
    Nov 16 2009
    Sandy eggo
    I was referring to $$$ but I didnt realize it came with the FW. I think its still a toss up between the AMD or clutchnet.
    Dec 03 2009
    PNW, Washington
    As far as pedal pressure went it feels the same as the other AMD clutches. Engagement is more toward the bottom where as the others are at the top. Very grabby but still able to slip it if you need to. Took a couple days to get used to compared to the 3. It took everything I threw at it, Launch control, flat shift, daily traffic, city driving, etc although my RS4 is supercharged so not a direct comparison as some of the big turbo 2.7t cars make a considerable more amount of torque. Even when I replaced it the clutch disk itself looked like it could have gone much longer.
    Sep 11 2009
    NE
    VER VERY Important point to AMD 1/2/3/3+ set up is that it is a marcel style clutch disc and only for that feature alone, on a daily driven car, I would not consider any other option that doesn't have marcel springs in it. This is solely why AMD 1/2/3/3+ is so easy to engage and drive in traffic.
    TO poster above, after spending mountains of money on several clutch set ups, it is just about the last area where I would experiment. I'd go with a proven set up.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    And the fact it still has the SAC to extend clutch life.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Nov 16 2010
    WetSide, WA
    If they are built on an oem center they will have the marcels, but the way the facings are riveted on often smashes them flat and makes them ineffective.
    Mar 29 2013
    Ontario, Canada
    94+meth
    Mar 29 2013
    Ontario, Canada
    Actually anyone one know what the AMD 3+ friction material is?
