Results 1 to 6 of 6
    Jul 18 2016
    buffalo ny
    Weak Heated Seats
    Anyone have issues with their heated seats being weak or is that just an audi thing? I have a semi bad back so I like to keep my heated seats on usually always. I've had VW's before and I never would turn them all the way up especially during the summer. I've noticed that ever since I bought my 12' Premium, I've had the warmers on level 6 and they still don't feel hot enough. Level 5 on my old R32 would fry an egg...
    Established Member Two Rings willski's Avatar
    May 08 2015
    2013 A4, 2.0T Quattro S-Tronic
    Melbourne, Aus
    Level 6? Mine only has 3 levels, and the hottest gets pretty toasty by my standards
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by willski View Post
    Level 6?
    PreFL B8 have 6 levels, you have facelift.
    Something for OP:
    http://www.audizine.com/forum/showth...275-Seat-Heat?
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    My '09 A4 with standard comfort seats.....I would never be able to go above 4 (on the 1-6 scale) on either driver or passenger sides. On my '15 Sline with sport seats I set it at "3" (1-3 scale now) and it's about what I would get from the 4 setting on my '09. There are some pretty significant variables with this including the hardware in the seats that may have changed from the manufacturer over the years, in addition to the differences int he seats themselves between comfort and sport.....
    The other thing I noticed is that with my '15 with the three stage seat heaters, they taper off as they get warmer.....so if I start at "3" I will notice after about 20 minutes it will have dropped down to just the "1 position. My '09 never did that.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Oct 13 2015
    2010 Audi A4 Quattro 6 speed manual, 1990 325i E30, 1980 450 SL
    Norcal
    My driver seat is like that where you think it should be hotter and it doesn't get there and yet all my passengers are always turning it down from 6 to about 4 after 5-10 minutes saying its too hot. Curious to see if there was a cheap fix rather than taking it somewhere and them saying replace the seat.
    May 27 2016
    Maine
    The drivers seat in my '10 P+ takes forever to heat up and then doe snot get very warm on the 6 setting. I commute 40 minutes and I don't feel heat until about 20 minutes and then when I arrive at work it is barely warm. Not usre about the passenger seat. I will have to test that.
    My previous Audis(1989 CQ, 1990 90q, 1996A4q) all had heated seats that I would normally not turn past halfway.
    Tim R.
    2010 A4q MT Premium+, Brilliant Black
    Injen intake
    Eiback Sportline Springs
